  • Jonas Gunnarsson 44 posts 194 karma points
    Jan 04, 2012 @ 14:11
    Jonas Gunnarsson
    Help with xslt-schema
    I have this blog jonasfotograf.se and I need help with my xslt-schema.
    This is how my tree structure looks like:
    Hem
     - Portfolio
     - Info/Om mig
     - Priser
     - Kontakt
     - Arkiv
     - rss
    And my problem is that I donĀ“t know how to change my xslt to show the Hem-node.
    xslt-code:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
     version="1.0"
     xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="msxml
    umbraco.library">
        <!-- update this variable on how deep your navigation should be -->
        <xsl:variable name="maxLevel" select="3"/>
        <xsl:template match="/">
            <ul id="menu">
                <xsl:call-template name="drawNodes">
                    <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@level=1 and @isDoc]"/>
                </xsl:call-template>
            </ul>
        </xsl:template>
        <xsl:template name="drawNodes">
            <xsl:param name="parent"/>
            <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)">
                <xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1' and @level &lt;= $maxLevel]">
                    <li>
                          <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1' and @level &lt;= $maxLevel]) &gt; 0">
                            <xsl:attribute name="class"><xsl:text>no-follow</xsl:text></xsl:attribute>
                        </xsl:if>
                        </a>
                            <ul>
                                    <xsl:with-param name="parent" select="."/>
                            </ul>
                        </xsl:if>
                    </li>
                </xsl:for-each>
            </xsl:if>
        </xsl:template>
    </xsl:stylesheet>
    Jan 04, 2012 @ 14:17
    Tom Fulton
    The problem is you're passing in the "parent" param as your Hem node, so it's starting out by looking for children under the Hem node.
    One way is to manually add the Hem node link in your XSLT file, ex:
            <ul id="menu">
                <li><a href="/">Hem</a></li>
            </ul>
    You could also try changing the parent xpath to start at the root "Content" node instead:
                    <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::root"/>
    Hope this helps,
    Tom
    Jan 04, 2012 @ 14:23
    Jonas Gunnarsson
    This solved my problem, many thanks!
    Best regards Jonas
