Hi guys,
Just quick question regarding 4.6.1 version, does some of the xslt code had become dysfunctional for example:
This does not work: select="./node" (works on 4.0.4.2 though)
But this works: select="./*"
Is there any other major changes that we need to take note of?
Thats just the first bad impression that I encounter while using the later version. Here is the real issue.
For some reason I just can't parse the value on my alias into input attribute, however I could use @nodeName to parse as value.
For example this works:
<xsl:element name="input"> <xsl:attribute name="type">hidden</xsl:attribute> <xsl:attribute name="value"><xsl:value-of select="./@nodeName" /></xsl:attribute> <xsl:attribute name="name">item_name</xsl:attribute> </xsl:element>
This turns out blank when executed:
<xsl:element name="input"> <xsl:attribute name="type">hidden</xsl:attribute> <xsl:attribute name="value"><xsl:value-of select="umbraco.library:Item(./@id,'foodDescription')" /></xsl:attribute> <xsl:attribute name="name">item_name</xsl:attribute> </xsl:element>
Strange thing is that <xsl:value-of select="umbraco.library:Item(./@id,'foodDescription')" /> rendered just fine outside the input attributes.
Any takers? or anyone experiencing the same issue?
Hi D-au,
Yes, the XML Schema had a major upgrade in v.4.5 (and later) - you should familiarise yourself with those here.
For your specific problem, try this instead:
<input type="hidden" name="item_name" value="{foodDescription}" />
/Chriztian
Hey Thanks /Chriztian
I'll take a look at those updates. Man, it is surprising how convenient the code is in comparison. Does the trick for me.
parsing value on input attribute issue 4.6.1
Hi guys,
Hi D-au,
<input type="hidden" name="item_name" value="{foodDescription}" />/Chriztian
