I'm going to start by apologising for using any incorrect terminoligy - first week using Umbraco after being thoroughly fedup with another .NET CMS!
I've installed the uComponents package and im using the Url picker. I'm now trying to write a simple Xslt macro that can be used multiple times on any given page. The following works, but you will notice it depends on the name of the field in the doctype being called area1Link - well what happens if I want to use the same macro more than once on a page?
I'm presuming that I need to extend the macro to pass a fieldname to it, but im not sure how to do that. I can see how to configure Umbraco to prompt you for a macro parameter, but how would I read it in the macro and get the value from the correct field name.
Any help anyone can provide would be greatly appreciated.
First step is to create a parameter on the macro so you can pass in the field name. Do this by going to Developer -> Macro -> (your macro) -> Parameters tab, and add a paramater (ie fieldAlias) of type Text. Then go back to your template and re-insert the macro, it will prompt you to enter the filedname.
Then here's a rough example of how to pull that into your XSLT file:
<xsl:param name="currentPage"/> <xsl:variable name="fieldAlias" select="/macro/fieldAlias" /> <!-- Grabs the fieldAlias macro param in a variable --> <xsl:variable name="fieldValue" select="$currentPage/* [not(@isDoc)][name() = $fieldAlias]" /> <!-- Grabs the value of a field matching $fieldAlias on the current page -->
Re-using uComponents url picker in Xslt
Hi all,
<!DOCTYPE xsl:stylesheet [
<!ENTITY nbsp " ">
<xsl:stylesheet
version="1.0"
xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:tagsLib="urn:tagsLib" xmlns:BlogLibrary="urn:BlogLibrary"
exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets tagsLib BlogLibrary ">
<xsl:template match="/">
<a>
<xsl:attribute name="href">
<xsl:value-of select="$currentPage/area1Link/url-picker/url" />
</xsl:attribute>
<xsl:if test="$currentPage/area1Link/url-picker/new-window[. = 'True']">
<xsl:attribute name="target">_blank</xsl:attribute>
</xsl:if>
Website link
</a>
</xsl:template>
</xsl:stylesheet>
thanks in advance
Al
HTH,
Tom
Tom,
Thanks so much mate - works like a treat!
Al
