  • Anuj 15 posts 35 karma points
    Feb 15, 2012 @ 09:00
    Anuj
    GetMedia System.OverflowException: Value was either too large or too small for an Int32.
    I am new to umbraco and working on media files and getting some problems.Please have a look at them and tell  me where i am wrong.
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
    <xsl:template match="/">
    <!-- start writing XSLT -->
      <xsl:value-of select="$currentPage/mediaItem"/>   // Its returning 1052
      <xsl:value-of select="umbraco.library:GetMedia($currentPage/mediaItem, 'false')"/>
      // Here is the error.
    </xsl:template>
    </xsl:stylesheet>
    When i use   <xsl:value-of select="umbraco.library:GetMedia($currentPage/mediaItem, 'false')"/>
    then its throwing error
    Error occured
    at System.Convert.ToInt32(Double value)
    at System.Double.System.IConvertible.ToInt32(IFormatProvider provider)
    at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
    at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
    at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlSequenceWriter results)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, XmlWriter results, XmlResolver documentResolver)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    If i use  <xsl:value-of select="umbraco.library:GetMedia(1052, 'false')"/>
    Then its perfect.Please tell me whats wrong in the above code.
    Feb 15, 2012 @ 15:03
    Tom Fulton
    You should wrap the GetMedia calls in a check to verify you have a value.  The reason is that when you press Save, Umbraco does a quick test of your XSLT file.  In this test it may not have a value for $currentPage/mediaItem - and this will cause an exception as GetMedia is expecting an integer.  Also this could happen if you run the macro on a page that doesn't have any media selected.
    So you can handle both situations by wrapping it in a test to ensure there is a value:
    <xsl:variable name="mediaId" select="$currentPage/mediaItem"/>
    <xsl:if test="$mediaId &gt; 0">
      <xsl:value-of select="umbraco.library:GetMedia($mediaId, false())"/>
    </xsl:if>
    Hope this helps,
    Tom
