  • jonok 297 posts 658 karma points
    Jul 15, 2009 @ 13:18
    jonok
    Get values of the current node, load a node by its id
    I want to display different menus depending on the document type of the current page. Does anybody know the XSLT for retrieving the @nodeTypeAlias (and other values) for the current page? I know the $currentPage param contains information for all pages, but how do I just select the current page node?
    And then I want to load a menu by selecting a top level node by its id, so how do I load a node by its id? eg: if the top level node id I want to use is 1048, then I want to call a menu template in this fashion (bold indicates the part I need help with):
    <xsl:call-template name="RenderMenu">
    <xsl:with-param name="parent" select="node(1048)"/>
    </xsl:call-template>
    Jul 15, 2009 @ 13:27
    Dirk De Grave
    102
    nerdalert,
    $currentPage contains info about current node as well, so
    $currentPage/@nodeTypeAlias
    does give the document type of the current page being processed.
    node(1048) needs to be replaced with
    umbraco.library:GetXmlNodeById(1048)
    (Also have a look at the wiki pages)
    /Dirk
    Jul 15, 2009 @ 13:34
    jonok
    Thanks Dirk, looks like there's loads of useful extensions in the Umbraco.Library
