  • Patrick 23 posts 83 karma points
    Mar 06, 2012 @ 20:53
    Patrick
    Structure problem
    I am working on a portfolio-site, which has the following structure:
    category
    + project 1
      + Image 1
      + Image 2
    + project 2
    I have the following code within my xslt to creat an overview of projects on my category page:
    <ul>
      <xsl:for-each select="$currentPage/* [@isDoc and string(umbracoNaviHide) != '1']">
        <li><a href="{umbraco.library:NiceUrl(@id)}">
        </xsl:if>
        </a></li>
    </xsl:for-each>
    </ul>
    What I really would want is to expand this code, so the first image of the first child is shown within the href instead of the nodeName. This way the image of: 'Image 1' is shown as the image for project 1.
    The image is called display.
    Any help is welcome...
    Mar 06, 2012 @ 21:13
    Kim Andersen
    Hi Patrick
    Maybe something like the following can help you:
    <ul>
        <xsl:if test="./*[@isDoc][1]/display != '' ">
            <xsl:variable name="media" select="umbraco.library:GetMedia(./*[@isDoc][1]/display,0)"/>
            <img src="$media/umbracoFile" alt="$media/@nodeName" />
        </xsl:if>
        </a></li>
    </xsl:for-each>
    </ul>
    /Kim A
    Mar 06, 2012 @ 21:33
    Patrick
    Thanks Kim,
    You made my day!
    Greetings, Patrick
    Mar 06, 2012 @ 21:36
    Kim Andersen
    Great! Glad to hear that Patrick :)
    /Kim A
