  • Martin 278 posts 662 karma points
    Mar 08, 2012 @ 10:34
    Martin
    Multiple Images with DAMP Problem
    Hi, Im trying to output multiple images using the DAMP.
    It works fine when I select only one image. But when mulitple images are selected, I get a parsing error.
    My XSLT is
    <xsl:template match="/">
    <h3>GALLERY</h3>
        <xsl:variable name="media" select="$currentPage/caseImage" />
        <xsl:for-each select="$media"
           <xsl:variable name="mediaNode" select="umbraco.library:GetMedia($media, 0)" />
           <img class="scale-with-grid" src="{$mediaNode/umbracoFile}" alt="{@nodeName}"/>
        </xsl:for-each>
    </xsl:template>
    From other posts on the forum, Ive seen the variable path point to "/DAMP/mediaItem/Image"
    Is this required somehow for DAMP?
    Any help would be grateful
    Martin
  • Chriztian Steinmeier 2800 posts 8790 karma points MVP 8x admin c-trib
    Mar 08, 2012 @ 12:07
    (DELETED)
    Mar 08, 2012 @ 12:12
    OK, I give up - tried to edit my answer but this editor just plain doesn't work the way it should, here's the corrected code:
    <xsl:variable name="media"select="$currentPage/caseImage/DAMP[@fullMedia]/mediaItem" />
    <!-- Inside for-each -->
    <xsl:variable name="mediaNode"select="Image" />
    /Chriztian
