my xml of macro container is:
<slideShow>
<?UMBRACO_MACRO macroalias="SlideShowHomeItem" linkArticolo="1078" imgAlternativa="" titleAlternativo="" />
<?UMBRACO_MACRO macroalias="SlideShowHomeItem" linkArticolo="1079" imgAlternativa="" titleAlternativo="" />
</slideShow>
My requirement is to read through a xslt/for-each properties of each macro in the macro container.
How can I do? Thanks to everyone for availability.
To be clearer, I have a macro container and a new macro I have to read through the items in the container macro.
I'm looking at every way to read items through the new macro with a foreach loop, but without success.
The XML above is generated by the macro container.
I hope you understand. Thanks in advance for the answer
I solved with XSLT extensions:
///<summary>
/// XSLT extensions, referenced from /config/xsltExtensions.config:
/// <ext assembly="/bin/MyAssembly" type="MyTypeName" alias="MyExtensions"/>
///</summary>
public class MyExtensions
private static Regex MacroExpression = new Regex("<?umbraco_macro (.*?)/>",
RegexOptions.Singleline | RegexOptions.IgnoreCase);
private static Regex PropertyExpression = new Regex("(\\S*?)=\"(.*?)\"",
public XPathNodeIterator DecodeMacroReferences(string input)
var doc = new XDocument();
var macros = new XElement("macros");
doc.Add(macros);
foreach (Match match in MacroExpression.Matches(input))
var macro = new XElement("macro");
foreach (Match propMatch in PropertyExpression.Matches(match.Groups[1].Value))
macro.Add(new XAttribute(propMatch.Groups[1].Value, propMatch.Groups[2].Value));
macros.Add(macro);
return doc.CreateNavigator().Select("/");
found at: http://www.rightpoint.com/community/blogs/viewpoint/archive/2010/09/29/treating-umbraco-macro-references-as-data.aspx
that has transformed the xml generated by the macro container:
<macros>
<macro macroalias="SlideShowHomeItem" linkArticolo="1078" imgAlternativa="" titleAlternativo="" />
<macro macroalias="SlideShowHomeItem" linkArticolo="1079" imgAlternativa="" titleAlternativo="" />
</macros>
Now I can access the properties of each element with a simple loop:
<xsl:variable name="macroSlideShow" select="$currentPage/slideShow" /><!--Alias Macro Container in Document Types-->
<xsl:for-each select="msxml:node-set(Ext.ItemMacroContainer:DecodeMacroReferences($macroSlideShow))/macros/child::*"> <xsl:variable name="currentNode" select="."/> <textarea> <xsl:value-of select="$currentNode/@linkArticolo"/> </textarea> </xsl:for-each>
Happy to have solved, I was about to leave.
Umbraco v 4.7.1.1
If there is a better solution let me know :-)
Help Parse Macro Parameters from Macro Container
<slideShow>
</slideShow>
{{{{macro.Add(new XAttribute(propMatch.Groups[1].Value, propMatch.Groups[2].Value));found at: http://www.rightpoint.com/community/blogs/viewpoint/archive/2010/09/29/treating-umbraco-macro-references-as-data.aspx
<macros>
</macros>
<textarea>
</textarea>
</xsl:for-each>
Umbraco v 4.7.1.1
