  • Maxime Dupierreux 5 posts 25 karma points
    Mar 23, 2012 @ 10:51
    Maxime Dupierreux
    Loading Xslt: Value was either too large or too small for an Int32.
    I've upgraded my Umbraco from 4.5.2 to 4.7.11 and one of my macro is now giving me this error :
      at System.Convert.ToInt32(Double value)
      at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
      at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
      at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
      at System.Xml.Xsl.CompiledQuery.Query.<xsl:template match="/">(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, XPathNavigator {urn:schemas-microsoft-com:xslt-debug}current, Double {urn:schemas-microsoft-com:xslt-debug}position, Double {urn:schemas-microsoft-com:xslt-debug}last, IList`1 {urn:schemas-microsoft-com:xslt-debug}namespaces) in C:\inetpub\website\xslt\WidgetLatestNewsWithNewsletter.xslt:line 57
      at System.Xml.Xsl.CompiledQuery.Query.<xsl:apply-templates>(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, XPathNavigator , Double , Double )
      at System.Xml.Xsl.CompiledQuery.Query.Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
      at System.Xml.Xsl.CompiledQuery.Query.Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
      at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer)
      at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
      at umbraco.macro.GetXsltTransformResult(XmlDocument macroXML, XslCompiledTransform xslt, Dictionary`2 parameters)
      at umbraco.macro.loadMacroXSLT(macro macro, MacroModel model, Hashtable pageElements)
    here's the xslt file :
    <!DOCTYPE xsl:stylesheet [
      <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
      version="1.0"
        <xsl:if test="$currentPage/@level &gt; 1">
          <xsl:variable name="fixedHref" >
            <xsl:call-template name="fixRssHref">
              <xsl:with-param name="niceUrl">
                <xsl:value-of select="umbraco.library:NiceUrl($currentPage/ancestor-or-self::* [@level = 2]//NewsArea/NewsPage/@id)" />
              </xsl:with-param>
            </xsl:call-template>
          </xsl:variable>
          <xsl:variable name="newsletterPage" select="$currentPage/ancestor-or-self:: * [@isDoc and @level = 2]//NewsLetterPage/@id"/>
          <!-- Classic Dual header -->
          <div class="mod classic lastnews">
            <b class="top">
              <b class="tl">
                <xsl:text> </xsl:text>
              </b>
              <b class="tr">
              </b>
            </b>
            <div class="inner shadow">
              <div class="hd newspaper">
                <a href="{concat($fixedHref, '/newsrss.aspx')}" class="rssLink">
                  <xsl:value-of select="umbraco.library:GetDictionaryItem('rss')"/>
                </a>
                <h3>
                  <xsl:value-of select="umbraco.library:GetDictionaryItem('latest_news')"/>
                </h3>
              <div class="bd">
                <div class="preview">
                  <xsl:for-each select="$currentPage/ancestor-or-self:: * [@isDoc and @level = 2]//NewsItem[string(umbracoNaviHide) != '1']">
                    <xsl:sort select="date" order="descending"/>
                    <xsl:if test="position() = 1">
                      <img src="/umbraco/imagegen.ashx?image={umbraco.library:GetMedia(image,'false')//umbracoFile}&amp;width=205&amp;height=136&amp;pad=true"  width="205" height="136" alt="{@nodeName}" />
                    </xsl:if>
                  </xsl:for-each>
                <div class="cnt">
                  <ul>
                      <xsl:if test="position() &lt; 4">
                        <li>
                          <!--<strong>
                            <xsl:value-of select="umbraco.library:FormatDateTime(date,'dd MMMM yyy')"/>
                          </strong>-->
                          <strong><a href="{umbraco.library:NiceUrl(@id)}">
                            </a></strong>
                            <xsl:value-of select="intro"/>
                            </a>
                        </li>
                      </xsl:if>
                    </xsl:for-each>
                  </ul>
                <a href="{umbraco.library:NiceUrl($currentPage/ancestor-or-self:: * [@isDoc and @level = 2]//NewsArea/@id)}" class="moreLnk">
                  <xsl:value-of select="umbraco.library:GetDictionaryItem('see_all_news')"/>
                </a>
                <div style="clear:both;">
              <div class="hd secondHd bubbles">
                <h3>
                  <xsl:value-of select="umbraco.library:GetDictionaryItem('newsletter_keepinformed')"/>
                </h3>
              <div class="bd">
                <label>
                  <xsl:value-of select="umbraco.library:GetDictionaryItem('newsletter_subscribe')"/> :
                </label>
                <input type="text" id="email" name="email" class="text labelify">
                  <xsl:attribute name="title">
                  <xsl:value-of select="umbraco.library:GetDictionaryItem('newsletter_email')"/>
                  </xsl:attribute>
                </input>
                <button onclick="document.location.href='{umbraco.library:NiceUrl($newsletterPage)}?email=' + document.getElementById('email').value;return false;">
                  <span>
                    <xsl:value-of select="umbraco.library:GetDictionaryItem('general_go')"/>
                  </span>
                </button>
            <b class="bottom">
              <b class="bl">
              </b>
              <b class="br">
              </b>
            </b>
          <!-- /Classic Dual header -->
        </xsl:if>
      </xsl:template>
      <xsl:template name="fixRssHref">
        <xsl:param name="niceUrl" />
        <xsl:variable name="indexOfAspx" select="umbraco.library:LastIndexOf($niceUrl, '.aspx')" />
          <xsl:choose>
            <xsl:when test="$indexOfAspx != -1">
              <xsl:value-of select="umbraco.library:Replace($niceUrl, '.aspx', '')" />
            </xsl:when>
            <xsl:otherwise>
              <xsl:value-of select="$niceUrl" />
            </xsl:otherwise>
          </xsl:choose>
        </xsl:variable>
        <xsl:value-of select="$fixedHref" />
      </xsl:template>
    </xsl:stylesheet>
    Can you tell me what's the problem with it?
    Thank you.
  • Grant Thomas 291 posts 324 karma points
    Mar 23, 2012 @ 11:09
    Grant Thomas
    Do you think you could cut down the XSLT to be a short, but complete example that would reproduce the problem?
    You could take the time to isolate exactly where the error is occuring, helping us help you by allowing concentration on the actual prooblem, without having to read every line of your code (most of which will be irrelevant).
    Mar 23, 2012 @ 11:11
    Maxime Dupierreux
    If I comment those lines, the macro is displaying.
                    </xsl:if>
                  </xsl:for-each>
  • Rodion Novoselov 694 posts 859 karma points
    Mar 23, 2012 @ 11:37
    Rodion Novoselov
    Hi. This error in validation-time is almost always caused by the GetMedia method. You can wrap the piece of Xslt calling it with an "if" statement to get rid of the error message. Like this:
    <xsl:if test="image">
    </xsl:if>
    The reason is that Xslt as being saved is validated against some real site page (afaik the root of the site) that doesn't necessary have all supposed properties (e.g. "image" in your case).
    Mar 23, 2012 @ 11:56
    Maxime Dupierreux
    Ok, I added an "if" like you said but it seems that it's missing something to test "image" with, because it's still trying to execute the GetMedia method.
    Mar 23, 2012 @ 12:16
    Rodion Novoselov
    Ok. Try a bit different than:
    <xsl:if test="string(image) != ''">
    Mar 23, 2012 @ 13:13
    Maxime Dupierreux
    Ok, it seems to be alright, the macro is rendered even if there is no image to display. I'll have to try with an image to display now.
    Do you know why the xslt was working on 4.5.2 and not on 4.7.11?
    Thank you for your help !
    Mar 23, 2012 @ 13:39
    Rodion Novoselov
    No idea. My first one was 4.6. Perhaps someone of elders can tell it.
