  • Eddie Foreman 215 posts 288 karma points
    Apr 03, 2012 @ 10:55
    Eddie Foreman
    Macro Parameters from another level 1 node
    Hi All,
    I have a site which has the following stucture:
    Home
        site pages
    Settings
         contact form
    The contact form is a usercontrol which is used on all pages.  The macro parameters would get the email to, subject, etc...  Normally I would do this using resursive parameters :
     <umbraco:Macro EmailSubject="[$emailSubject]" EmailTo="[$emailTo]" Alias="ContactForm" runat="server"></umbraco:Macro>
    The above approach takes me to the home node. I was wondring if it's possible to traverse to the root node, then down the settings node.
    Eddie
    Apr 03, 2012 @ 12:08
    Lee Kelleher
    Hi Eddie,
    As far as I know, it is not currently possible to specify/define which node the macro parameters get their values from. You would need to do that inside the macro itself.
    In contrast the <umbraco:Item> actually has a "NodeId" parameter which sets the context of the "Item" / value. Something like that might be useful for the Macro control/tag too.
    Cheers, Lee.
    Apr 05, 2012 @ 00:53
    Eddie Foreman
    Hi Lee,
    Thanks for the info.  Ending up using the  Node API route to gain access to the required data.
    Eddie
