  • Sander van de Pas 74 posts 147 karma points
    Apr 27, 2012 @ 13:26
    Sander van de Pas
    How to add variable as element
    Dynamically I get the languageCode (e.g. nl or en or us) and put this in a variable. After that I want to use this variable as a property from a media item.
    Instead of $media/umbracoFile I need $media/nl or $media/en or $media/uk depending on the languageCode.
    I tried a lot of things but nothing works.
    Here's my code:
    <xsl:variable name="language" select="$currentPage/ancestor-or-self::Home[@isDoc]" />
    <xsl:variable name="languageCode" select="$language/language" />
    <xsl:for-each select="$currentPage/productDownloads/MultiNodePicker/nodeId">
     <xsl:variable name="media" select="umbraco.library:GetMedia(., false())" />
            <li>
    <a href="{$media/umbracoFile}" target="_blank">
    <xsl:value-of select="$media/[$languageCode]" />
    </a>
    </li>
    </xsl:for-each>
    Could someone help me?
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Apr 27, 2012 @ 13:32
    Hi Sander,
    You do that using the name() function:
    <xsl:value-of select="$media/*[name() = $languageCode]" />
    /Chriztian
    Apr 27, 2012 @ 14:37
    Sander van de Pas
    Problem was the UPPERCASE of the variable languageCode :-(.
    Now it works!
