I can return the numeric value of the dropdown 'articleType'. I cant seem to get the text value using GetPreValueAsString. Thows an error when I add the line in italic containing the function. Tried ignoring errors but it wont parse.
<tr>
<td class="content-kb-title"><a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a></td> <td class="content-kb-doctype"> <xsl:if test="./articleType > 0"> <xsl:value-of select="./articleType"/> <xsl:value-of select="umbraco.library:GetPreValueAsString(./articleType)"/> </xsl:if> </td> <td class="content-kb-lastdate"><xsl:value-of select="umbraco.library:FormatDateTime(@updateDate, 'd')"/></td> </tr>
Error occured
System.Xml.Xsl.XslTransformException: Extension functions cannot return null values. at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltResult(XmlQueryType xmlType, Object value) at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args) at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime) at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime) at Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime) at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlSequenceWriter results) at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer) at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, XmlWriter results, XmlResolver documentResolver) at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results) at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
The italics dissapeared. the line that throws the error is:
I can type in random numbers and sometimes get a result.
Cheers.
Hi Daniel,
It sounds like the prevalue could have been deleted - could that be the case?
Your code probably runs on a number of nodes - if one of them has a deleted prevalue stored, it will most likely fail.
/Chriztian
Hi Chriztian,
thanks for the reply. How do I fix that?
Dan
My bad.
It was an Ultimate picker and the value was a node id. :-(
Upload image
GetPreValueAsString wont work for me.
<tr>
</xsl:if>
</td>
</td>
</tr>
Error occured
Cheers.
Hi Daniel,
/Chriztian
Hi Chriztian,
Dan
My bad.
