<xsl:value-of select="Exslt.ExsltDatesAndTimes:formatdate(@createDate, 'dd MM yyyy')"/> <xsl:value-of select="umbraco.library:FormatDateTime(@createDate, 'dd MM yyyy')"/>
Which is better to use? Of the examples I've seen (from community packages etc), people always seem to use the umbraco.library way, but the Exslt seems a little more intuative to me.
The Exslt extensions are a standard library (see www.exslt.org) that Per added to get even more capabilities in xslt. It has some overlap with functions that were already in the umbraco.library extension, such as the FormatDataTime(). I've used both and never had a problem with either. Though, on the other hand, if you find one works better for you, has more features, or works more to your liking... use that one!
Difference between umbraco.library and Exslt?
Just wondering...
What's the difference between (for example):
I think that's mainly due to the fact that Exslt has been part of the core since v4. Previous to that you had to manually add it.
Have not tried to compare the two, but there are more options with Exslt (which is why I used it with v3).
Hi, Lesley,
cheers,
doug.
