  • Giovanni Sidoel 94 posts 233 karma points
    May 16, 2012 @ 18:18
    Giovanni Sidoel
    Is it possible to retrieve the destination node when redirected to Login using XSLT
    Hi guys,
    I'm currently creatin a news site that requires membership. I'm using out-of-the-box umbraco membership. What I want to do is: when you navigate to the newsitem, instead of only seeing the login form (standard asp:Login), I want to also include part of the page. Say a picture and som intro text.
    The problem is that when you get redirected to the Login page I don't have any information (nodeId and such) on the page that I'm trying to view to get that information.
    Can I, using xslt, somehow retrive the nodeId of the page that I was trying to view?
    Thanks.
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    May 16, 2012 @ 22:19
    Jeroen Breuer
    2
    If you use uComponents there is an extension called GetNodeByUrl. You could try to call that as an XSLT extension and pass in the url if it's in the querystring. Otherwise I don't know how to do it.
    Jeroen
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 9x admin c-trib
    May 16, 2012 @ 22:42
    Hi Giovanni,
    On a site I'm currently building, I'm using the Single Password security — when I try to access a protected page, the browser stays on the requested URL, but Umbraco renders the selected Login page; So as Jeroen suggests, it should be possible to grab the URL from the headers (e.g.: umbraco.library:RequestServerVariables('URL') and pass that to the uComponents extension...
    Does that make sense?
    /Chriztian
    May 17, 2012 @ 13:09
    Giovanni Sidoel
    GENIUS! PURE GENIUS!
    Thanks a lot for the tip guys. To be honest, I had already given up and started passing the nodeId as a querystring parameter, which was just an ugly way of doing it.
    Great community we have.
    Yet another great solution provided by uComponents.
    Cheers!
    Gio
