Multi-level nav with XSLT, displaying children of multiple parents
I am looking for a way to display links in a sidebar that display each parent node and its children. It is easy enough to display one set of parents and children, but I am having trouble getting multiples to work. This is the output goal:
If you hover over the "About" tab on the horizontal nav, you'll see that there are two sets of links, one under "Camp Qwanoes" and another under "Briercrest College & Seminary". These two are the parent folders, both under "About". I want to display both sets of child nodes in the side menu when viewing on of the pages in the About section.
As far I can see you are very close. If I should guess you are missing selecting descendant in subMenuTopLevelNodes... some thing like <xsl:variable name="subMenuTopLevelNodes" select="$currentPage/ancestor-or-self::* [@level = 2]/descendant::* [@isDoc and umbracoNaviHide != 1]"/>
<sidebar>
Parent 1
-- child 1
-- child 2
-- child 3
Parent 2
-- child 1
-- child 2
-- child 3
</sidebar>
I have this working part way, thanks to a solution posted by Sune Jepsen and Thijs Kuipers at http://our.umbraco.org/forum/developers/xslt/15660-multi-level-menu, but it doesn't quite do what I want, and I'm having trouble because I haven't worked with xsl:call-template before.
The output of the XSLT below is:
<sidebar>
Parent 1
-- child 1
-- child 2
-- child 3
Parent 2 (without any children beneath it)
</sidebar>
Here is the XSLT I am using: My guess is that something needs to be changed in the nested xsl:choose clauses, but I'm not sure where to go from here.
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="msxml umbraco.library"> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <xsl:template match="/"> <xsl:variable name="subMenuTopLevelNodes" select="$currentPage/ancestor-or-self::* [@level = 2]/* [string(umbracoNaviHide) != '1' and @isDoc]"/> <xsl:if test="count($subMenuTopLevelNodes) > 0"> <h1><xsl:value-of select="$currentPage/../@nodeName" /></h1> <nav> <xsl:call-template name="submenuTree"> <xsl:with-param name="pageNodes" select="$subMenuTopLevelNodes"/> </xsl:call-template> </nav> </xsl:if> </xsl:template> <xsl:template name="submenuTree"> <xsl:param name="pageNodes"/> <xsl:for-each select="$pageNodes"> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:choose> <xsl:when test="count(current()/*[string(umbracoNaviHide) != '1' and @isDoc]) > 0"> <xsl:choose> <xsl:when test="$currentPage/@level >= current()/@level and @id = $currentPage/ancestor-or-self::*[@level=current()/@level]/@id"> <xsl:attribute name="class">show-children</xsl:attribute> <xsl:if test="$currentPage/@id = @id"> <xsl:attribute name="class">show-children selected</xsl:attribute> </xsl:if> </xsl:when> <xsl:otherwise> <xsl:attribute name="class">has-children</xsl:attribute> <xsl:if test="$currentPage/@id = @id"> <xsl:attribute name="class">has-children selected</xsl:attribute> </xsl:if> </xsl:otherwise> </xsl:choose> </xsl:when> <xsl:otherwise> <xsl:if test="$currentPage/@id = @id"> <xsl:attribute name="class">selected</xsl:attribute> </xsl:if> </xsl:otherwise> </xsl:choose> <xsl:value-of select="@nodeName"/> </a> <xsl:if test="$currentPage/@level >= current()/@level and @id = $currentPage/ancestor-or-self::*[@level = current()/@level]/@id and count(current()/*[string(umbracoNaviHide) != '1' and @isDoc]) > 0"> <xsl:call-template name="submenuTree"> <xsl:with-param name="pageNodes" select="$currentPage/ancestor-or-self::*[@level = current()/@level]/*[string(umbracoNaviHide) != '1' and @isDoc]"/> </xsl:call-template> </xsl:if> </xsl:for-each> </xsl:template> </xsl:stylesheet>Your assistance is enormously appreciated!
PS: if it would help to see what I'm working on, the XSLT file above is employed here: http://kaleo.briercrest.ca/about/camp-qwanoes/about-qwanoes/
Hi Luke
I think this link could help you: http://pimpmyxslt.com/axesviz.aspx?contextNode=1066&axis=descendant#screen
Hope it works out.
