I got the same issue. The macro displays fine in every possible way except when I use it in the TinyMCE and then put in on the page through XSLT.
Disabling output escaping just renders nothing. Enabling it renders:
<?UMBRACO_MACRO macroAlias="someMacro" />
The macro renders in templates, and when the tinyMCE is displayed through the item field. When the tinyMCE field is called through XSLT to display, this bug occurs.
Has this been resolved? I'm running umbraco v 4.7.0 (Assembly version: 1.0.4090.38017) and this issue is still in play.
My setup is:
Template -> XSLT macro that outputs some content from the current node AND loads a specific node from elswhere in the content hierachy. -> The node loaded has a richtext field which contains a macro. This macro is not rendered.
If i put the macro directly on the template, the macro renders. However this does not solve my problem. It HAS to render inside the richtext field.
So, what didnt work for me before was in my XSLT: <xsl:value-of disable-output-escaping="yes" select="comment_content"/>
where comment_content was a richtext field that had a macro on it, and the macro didnt render. If I change the line above to: <xsl:value-of select="umbraco.library:RenderMacroContent(comment_content, @id)" disable-output-escaping="yes"/>
Everything works like a charm. Jan, I cannot thank you enough :)
Xslt macro does not render on page
Hello all.
I believe this has come up before as I have been trawling the forums trying to find an answer.
Essentially, a macro that I am trying to implement creates fine in the tinymce, but on the page it displays:
The xslt macro is:
Does anybody have any other solutions in order to add html to the tinymce editor? I see that the is this solution [ http://forum.umbraco.org/yaf_postst5126_Parsing-ltUMBRACOMACRO-gt-tags-with-xsl-when-embedded-within-data-node.aspx ] but I am unsure how to implement it.
Any help would be greatly appreciated!
Cheers.
Did you insert it through the 'Insert Macro' button in the rich text editor?
Have you checked the properties of that particular macro to ensure that it's able to be used/displayed in the RTE?
Hi Daniel,
I have tried the insert button and with 'Display in Editor' checked and then again not checked to see if that was the case.
The macro does display in the editor but only displays the
on the page. I have tried different macros and all come out as a version above.
Hey urg
Which version of Umbraco are you using? If remember correctly there can be some issues with macros in the RTE in Umbraco 3.x.x
http://umbraco.codeplex.com/WorkItem/View.aspx?WorkItemId=21728
http://forum.umbraco.org/yaf_postst8677_XSLT-Macro-not-rendering-to-page.aspx
So until it get fixed you should find another way to get to your goal
i am having similar problems with the RTE and macros ...
Think this is a major issue with newer versions of umbraco that should have a top priority in getting fixed ..
and yes - i have done my bit of trying to figure out what the problem might be .. :s
umbraco v 4.0.3 (Assembly version: 1.0.3625.27276)
My setup is:
Template ->
thanks.
/Thomas
Hi Thomas
Is the macro inside your RTE based on a XSLT file or is it based on a Razor file or user control? Just for the record this issue is not a bug :)
If it's based on a XSLT file you should probably use umbraco.library:RenderMacroContent() to render the content from your RTE field.
Hope this helps.
Hi Jan, your always on the spot ;) Are you not supposed to be celebrating cristmas or something? :)
It's an XSLT file. I'll take a look at umbraco.library:RenderMacroContent() right away.
/Thomas
Haha, well Christmas is still a couple of ours away, isn't it? ;-)
But you're right, time to sign off and enjoy the holidays. Hope you figure it out.
Worked perfectly.
All the best
Thomas
