I have a xsl variable which need to be call inside a javascript, how can this be done ? i've tried varies of way but still no luck. please help. here is an example.
on this line window.location = 'http://server-name/mobilemoviedetail.aspx?movieID=-2';
i want to replace the "-2" to <xsl:value-of select="$movieID"/>
You can just do a <xsl:value-of /> where you want it - you should look into using a CDATA Section for all the JavaScript, so you don't have to escape stuff, e.g.:
<script type="text/javascript"><![CDATA[
var agentID = navigator.userAgent.toLowerCase().match(/(android|webos|iphone|ipad|blackberry|avantgo|blazer|compal|elaine|hiptop|iris|kindle|lge|maemo|midp|mmp|mobile|o2|opera|palm)/);
if (agentID)
if (document.cookie.indexOf("iPhoneRedirect")==-1 && (navigator.userAgent.toLowerCase().match(/iphone/i) || navigator.userAgent.toLowerCase().match(/ipod/i) || navigator.userAgent.toLowerCase().match(/ipad/i))) window.location = "http://server-name/mobilesplashiphone";
else if (document.cookie.indexOf("AndroidRedirect") == -1 && (navigator.userAgent.toLowerCase().match(/android/i))) window.location = "http://server-name/mobilesplashandroid";
else if (window.location.href.indexOf('movie-detail.aspx')!=-1)
window.location = 'http://server-name/mobilemoviedetail.aspx?movieID=]]><xsl:value-of select="$movieID" /><![CDATA[';
else if (window.location.href.indexOf('weekly-email.aspx?status=unsubscribed')!=-1)
var lURL = String(window.location.href);
var lPos = lURL.indexOf('?');
window.location = 'http://server-name/mobileweeklyemail.aspx'+lURL.substr(lPos,(lURL.length-lPos));
else if (window.location.href.indexOf('movie-detail.aspx')==-1) window.location = 'http://server-name/mobilehome.aspx';
</script>
I will say, however, that a much better solution will be to put the JS functionality into a function in a separate file, and just generate a simple function call in the XSLT.
call xsl variable inside javascript
on this line
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:LocationSearchXslt="urn:LocationSearchXslt" xmlns:umbraco.contour="urn:umbraco.contour"
exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets LocationSearchXslt umbraco.contour ">
<xsl:template match="/">
<xsl:variable name="movieID">
<xsl:choose>
<xsl:when test="contains(umbraco.library:RequestServerVariables('URL'),'movie-detail.aspx') and string-length(umbraco.library:RequestQueryString('node_id'))>0">
<xsl:value-of select="umbraco.library:GetXmlNodeById(umbraco.library:RequestQueryString('node_id'))/movie_id"/>
</xsl:when>
<xsl:otherwise>-1</xsl:otherwise>
</xsl:choose>
</xsl:variable>
<xsl:choose>
<xsl:when test="string-length(umbraco.library:Split(umbraco.library:RequestCookies('sitetype'),',')/value) = 0">
if (agentID)
if (document.cookie.indexOf("iPhoneRedirect")==-1 <xsl:value-of select="'&&'" disable-output-escaping="yes"/> (navigator.userAgent.toLowerCase().match(/iphone/i) || navigator.userAgent.toLowerCase().match(/ipod/i) || navigator.userAgent.toLowerCase().match(/ipad/i))) window.location = "http://server-name/mobilesplashiphone";
else if (document.cookie.indexOf("AndroidRedirect") == -1 <xsl:value-of select="'&&'" disable-output-escaping="yes"/> (navigator.userAgent.toLowerCase().match(/android/i))) window.location = "http://server-name/mobilesplashandroid";
</script>
</xsl:when>
</xsl:choose>
</xsl:template>
</xsl:stylesheet>
Hi bev0,
<script type="text/javascript"><![CDATA[ var agentID = navigator.userAgent.toLowerCase().match(/(android|webos|iphone|ipad|blackberry|avantgo|blazer|compal|elaine|hiptop|iris|kindle|lge|maemo|midp|mmp|mobile|o2|opera|palm)/); if (agentID) { if (document.cookie.indexOf("iPhoneRedirect")==-1 && (navigator.userAgent.toLowerCase().match(/iphone/i) || navigator.userAgent.toLowerCase().match(/ipod/i) || navigator.userAgent.toLowerCase().match(/ipad/i))) window.location = "http://server-name/mobilesplashiphone"; else if (document.cookie.indexOf("AndroidRedirect") == -1 && (navigator.userAgent.toLowerCase().match(/android/i))) window.location = "http://server-name/mobilesplashandroid"; else if (window.location.href.indexOf('movie-detail.aspx')!=-1) { window.location = 'http://server-name/mobilemoviedetail.aspx?movieID=]]><xsl:value-of select="$movieID" /><![CDATA['; } else if (window.location.href.indexOf('weekly-email.aspx?status=unsubscribed')!=-1) { var lURL = String(window.location.href); var lPos = lURL.indexOf('?'); window.location = 'http://server-name/mobileweeklyemail.aspx'+lURL.substr(lPos,(lURL.length-lPos)); } else if (window.location.href.indexOf('movie-detail.aspx')==-1) window.location = 'http://server-name/mobilehome.aspx'; }]]> </script>/Chriztian
