  • Sean 141 posts 179 karma points
    Jun 30, 2012 @ 08:28
    Sean
    Navigation - test for child nodes and display not working as expected
    Hi There,
    I'm having osme issues with my nav macro. I'd like to display all the nodes from the root and test if each node has child nodes and in turn display those.
    Your help is much appreciated!
    ---- Ideal Structure
    - main link
    - main link
    -- sub link
    -- sub link
    - main link
    -- sub link
    -- sub link
    -- sub link
    - main link
    -- sub link
    - main link
    <!DOCTYPE xsl:stylesheet [
      <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
     version="1.0"
      <!-- <xsl:param name="parent"  select="$currentPage/ancestor-or-self::* [@level=1 and @isDoc]"/>-->
     <!-- <xsl:variable name="parent" select="$currentPage/ancestor-or-self::*[@level = 1]" /> -->
       <xsl:variable name="parent" select="$currentPage/ancestor-or-self::* [@level='1']" />
      <xsl:template match="/">
        <xsl:variable name="maxLevel" select="4"/>
        <ul class="sf-menu">
          <li>
            <a href="/">
              <xsl:text>Home</xsl:text>
            </a>
          </li>
          <xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1' and @level &lt;= $maxLevel]">
            <!-- Original  <xsl:for-each select="$currentPage/* [@isDoc and string(umbracoNaviHide) != '1']">-->
            <li>
              </a>
            <xsl:variable name="child" select="umbraco.library:GetXmlNodeById(@id)/*[@isDoc]"/>
              <xsl:if test="count($child) > 0">
                <ul>
                  <xsl:for-each select="$currentPage [@isDoc and string(umbracoNaviHide) != '1']">
                    <li>
                      </a>
                    </li>
                  </xsl:for-each>
                </ul>
              </xsl:if>
            </li>
          </xsl:for-each>
        </ul>
      </xsl:template>
    </xsl:stylesheet>
  • Fuji Kusaka 2203 posts 4220 karma points
    Jun 30, 2012 @ 11:50
    Fuji Kusaka
    Hi Sean,
    Here is how you could get youre navigation to display all nodes and child nodes if any is present and where umbracoNaviHide is not set to true.
    <xsl:variable name="parent" select="1111"/> <!-- here you can add your parent NodeID -->
    <xsl:variable name="parentNode" select="umbraco.library:GetXmlNodeById($parent)" />
    <xsl:for-each select="$parentNode/* [@isDoc][not(umbracoNaviHide = 1)]">
    <xsl:element name="li">
    </a>
    <!-- Test if there is any Child Nodes  -->
    <xsl:if test="*[@isDoc][not(umbracoNaviHide = 1)]">
    <ul>
    <xsl:for-each select="./* [@isDoc and string(umbracoNaviHide) !='1']"><xsl:element name="li"><a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a>
    </xsl:element>
    </xsl:for-each>
    </ul>
    </xsl:if>
    </xsl:element>
    </xsl:for-each>
    </ul>
    This is just a way of doing it and from the example am assuming the home or default node will not be displayed.
    //fuji
    Jul 01, 2012 @ 10:05
    Sean
    Hi Fuji,
    Thanks very much. I added the code you posted into my macro and it worked like a treat. I used a portion of it for the child nodes recursion.
    Sean
    <xsl:stylesheet
     version="1.0"
          <li>
            <a href="/">
            </a>
          </li>
            <li>
              </a>
              <ul>
                <li><a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a>
              </li>
              </xsl:for-each>
              </ul>
              </xsl:if>
            </li>
          </xsl:for-each>
        </ul>
      </xsl:template>
    </xsl:stylesheet>
