I'm still working out the kicks of everything and don't really understand everything so it could be something that already is explained somewhere
anyway
i've got a carousel image thing on my site
i want it to grab the images that it uses out of my media library
how can i do this
i was thinking of an xslt but i don't know how to write it
example:<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:twitter.library="urn:twitter.library" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets twitter.library "><xsl:output method="xml" omit-xml-declaration="yes"/><xsl:param name="currentPage"/><xsl:template match="/"> <div id="rotating-item-wrapper"> <img class="rotating-item" src="/images/img/photos/1.jpg" /> <img class="rotating-item" src="/images/img/photos/2.jpg" /> <img class="rotating-item" src="/images/img/photos/3.jpg" /> <img class="rotating-item" src="/images/img/photos/4.jpg" /> </div></xsl:template></xsl:stylesheet>
so change the img files so it selects these images from my media library
so i don't have to keep changing the code
Please help me
Hi David,
Here's a very simple way to do it:
Create a property called Media Folder and choose the Media Picker Data Type (It should get the alias mediaFolder).
Now replace the <xsl:template match="/"> ... </xsl:template> in the above XSLT with these three templates:
<xsl:template match="/"> <xsl:variable name="mediaFolderId" select="$currentPage/mediaFolder" /> <!-- Make sure a folder was picked --> <xsl:if test="normalize-space($mediaFolderId)"> <xsl:variable name="mediaFolder" select="umbraco.library:GetMedia($mediaFolderId, true())" /> <!-- Process folder, if it exists --> <xsl:apply-templates select="$mediaFolder[not(error)]" /> </xsl:if> </xsl:template> <xsl:template match="Folder"> <div id="rotating-item-wrapper"> <!-- Process images in folder --> <xsl:apply-templates select="Image" /> </div> </xsl:template> <xsl:template match="Image"> <img class="rotating-item" src="{umbracoFile}" width="{umbracoWidth}" height="{umbracoHeight}" /> </xsl:template>
On the document you can now select a folder in your Media Section and have all the images processed by the single Image template.
/Chriztian
Thanks a million i have been looking and trying to find a solution.exactly what i needed
Greets
David
As usual thumbs up for Chriztian. Awesome.
I need help with media library
anyway
how can i do this
example:
<xsl:stylesheet
version="1.0"
</xsl:template>
</xsl:stylesheet>
Please help me
Hi David,
<xsl:template match="/"> <xsl:variable name="mediaFolderId" select="$currentPage/mediaFolder" /> <!-- Make sure a folder was picked --> <xsl:if test="normalize-space($mediaFolderId)"> <xsl:variable name="mediaFolder" select="umbraco.library:GetMedia($mediaFolderId, true())" /> <!-- Process folder, if it exists --> <xsl:apply-templates select="$mediaFolder[not(error)]" /> </xsl:if> </xsl:template> <xsl:template match="Folder"> <div id="rotating-item-wrapper"> <!-- Process images in folder --> <xsl:apply-templates select="Image" /> </div> </xsl:template> <xsl:template match="Image"> <img class="rotating-item" src="{umbracoFile}" width="{umbracoWidth}" height="{umbracoHeight}" /> </xsl:template>On the document you can now select a folder in your Media Section and have all the images processed by the single Image template.
/Chriztian
Greets
David
