  • Cre8tive 7 posts 27 karma points
    Aug 09, 2012 @ 17:40
    Cre8tive
    Adding JW Player ... Need a little help
    Thank you in advance for any help provided...
    I'm a complete newb in Umbraco, know nothing about ASP.NET, and am utterly lost ... so pelase be gentle.
    I am working on a site that needs a video player and decided to go with JW Player because that is what I am most familiar with. I created the XLST and Macro and everything is working except for the image thumbnail.
    I may be missing a step (since I am new to this) or there may be something wrong with my code. I basically took the videoNode (which works) and duplicated it for the imageNode.
    ---------------------------------------------------XLST---------------------------------------------------
    <!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
    <xsl:output method="html" omit-xml-declaration="yes"/>
    <xsl:variable name="videonode" select="/macro/videoNode"/>
    <xsl:variable name="videoid" select="generate-id($videonode)"/>
    <xsl:variable name="videopath" select="$videonode/File/umbracoFile"/>
    <xsl:variable name="videoheight" select="/macro/VideoHeight"/>
    <xsl:variable name="videowidth" select="/macro/VideoWidth"/>
    <xsl:variable name="imagenode" select="/macro/imageNode"/>
    <xsl:variable name="imageid" select="generate-id($imagenode)"/>
    <xsl:variable name="imagepath" select="$imagenode/File/umbracoFile"/>
    <xsl:template match="/">
    <!-- JW Player ============================================================= -->
    <script type='text/javascript' src='/scripts/jwplayer/jwplayer.js'></script>
    <div id='mediaspace'>This text will be replaced</div>
    <script type='text/javascript'>
      jwplayer('mediaspace').setup({
        'flashplayer': '/scripts/jwplayer/player.swf',
        'file': '<xsl:value-of select="$videopath" />',
        'image': '<xsl:value-of select="$imagepath" />',
        'backcolor': 'FFFFFF',
        'frontcolor': '0079c1',
        'lightcolor': 'FFFFFF',
        'screencolor': 'FFFFFF',
        'bufferlength': '25',
        'controlbar': 'bottom',
        'width': '<xsl:value-of select="$videowidth"/>',
        'height': '<xsl:value-of select="$videoheight"/>' <!-- NOTE: must add 24px height to accomodate player control bar -->
    </script>
    </xsl:template>
    </xsl:stylesheet>
    ---------------------------------------------------The Resulting Macro in the Editor---------------------------------------------------
    <div umb_imagenode="2064" umb_videonode="2060" umb_macroalias="JwPlayer" umb_videoheight="531" umb_videowidth="902" ismacro="true" onresizestart="return false;" umbversionid="e51c497e-99a4-4d75-b514-02821778849a" umbpageid="2019" title="This is rendered content from macro" class="umbMacroHolder"><!-- startUmbMacro --><span style="color: green;"><strong>JW Player</strong><br />No macro content available for WYSIWYG editing</span><!-- endUmbMacro --></div>
    ---------------------------------------------------The Resulting HTML---------------------------------------------------
    As you can see the "image" (thumbnail) is left blank. Everthing else works perfect.
    <script type="text/javascript" src="/scripts/jwplayer/jwplayer.js"></script><div style="position: relative; width: 902px; height: 531px;" id="mediaspace_wrapper"><object tabindex="0" name="mediaspace" id="mediaspace" bgcolor="#000000" data="/scripts/jwplayer/player.swf" type="application/x-shockwave-flash" height="100%" width="100%"><param value="true" name="allowfullscreen"><param value="always" name="allowscriptaccess"><param value="true" name="seamlesstabbing"><param value="window" name="wmode"><param value="netstreambasepath=http%3A%2F%2Ftestca.chrsolutions.com%2Fvideo%2Fomnia360promo%2F&amp;id=mediaspace&amp;file=%2Fmedia%2F10819%2Fomnia360promo.flv&amp;image=&amp;backcolor=FFFFFF&amp;frontcolor=0079c1&amp;lightcolor=FFFFFF&amp;screencolor=FFFFFF&amp;bufferlength=25&amp;controlbar.position=bottom" name="flashvars"></object></div><script type="text/javascript">
        'file': '/media/10819/omnia360promo.flv',
        'image': '',
        'width': '902',
        'height': '531'
    </script>
    ---------------------------------------------------The Macro Parameters---------------------------------------------------
    Aug 10, 2012 @ 03:50
    Tom Fulton
    Welcome to Umbraco!
    I think your issue is that your XSLT for the imagepath is looking for a "File" element where it should be an "Image" element.  The XML in Umbraco stores as elements of the Document or Media Type's alias, for example <Homepage> or <Image>, <File>, etc.  (more info here)  Normally this isn't an issue using GetMedia etc, but the mediaCurrent macro parameter happens to return the parent element as well.
    So you can change to this:
    <xsl:variable name="imagepath" select="$imagenode/Image/umbracoFile"/>
    Or to encompass any media type you could use this also:
    <xsl:variable name="imagepath" select="$imagenode/*/umbracoFile"/>
    Hope this helps,
    Tom
    Aug 10, 2012 @ 15:39
    Cre8tive
    Perfect! Thank you.
