Are you sure that there has actually been chosen an image for the image node with the name of 1100? Could you perhaps show a screendump from the backoffice?
If the image has been mapped correctly then try having a look at this issue: http://issues.umbraco.org/issue/U4-776 - Seems like inline editing is perhaps broken in some scenarios.
Images not appearing in 4.9
I have a freshly installed umbraco 4.9, and I have an issue showing images from media picker in a template.
My code in the template like this:
and result when i run the page is:
Any idea what I am doing wrong?
Thank you.
Hi Khaled
Hope this helps.
I downloaded the bin file and it solved my issue.
Khaled
hey I think u have the same issue.....
Freshly downloaded 4.9 setup.
yup, it's fixed with the patched umbraco.dll.
tnxs Sebastiaan! #h5yr
