  • syn-rg 282 posts 425 karma points
    Nov 02, 2012 @ 02:28
    syn-rg
    XSLTsearch page navigation using input onchange
    I have created a pagination input that on change will go to the value entered into the input.
    It will detect the page range and allow navigation between those pages in that range. e.g /image-gallery-album-1.aspx?page=3
    <form type="get" onchange="return false">
      <div class="pagerUI">
        <table border="0" cellspacing="0" cellpadding="0">
          <tr>
            <!-- previous page -->
            <xsl:if test="$page &gt; 1">
              <td class="pager-prev"><a class="previous" href="{concat('?page=', $page - 1, $qs)}" title="Previous page">&#8249;</a></td>
            </xsl:if>
            <td>Page</td>
            <td><input type="number" name="page" id="page" min="1" >
              <xsl:choose>
                <xsl:when test="$page=1">
                  <xsl:attribute name="value">1</xsl:attribute>
                </xsl:when>
                <xsl:otherwise>
                  <xsl:attribute name="value"> <xsl:value-of select="$currentPageNumber" /> </xsl:attribute>
                </xsl:otherwise>
              </xsl:choose>
              <xsl:attribute name="max"> <xsl:value-of select="$numberOfPages"/> </xsl:attribute>
              </input></td>
            <td>of <xsl:value-of select="$numberOfPages"/></td>
            <!-- next page -->
            <xsl:if test="$page * $resultsPerPage &lt; count($matchedNodes)">
              <td class="pager-next"><a class="next" href="{concat('?page=', $page + 1, $qs)}" title="Next page">&#8250;</a></td>
            </xsl:if>
          </tr>
        </table>
    </form>
    However, when I added this to the XSLTSearch code it doesn't work as the URL loses the search string.
    So instead of navigating to: /image-search.aspx?search=football&page=3
    It navigates to: /image-search.aspx?page=3 Which doesn't display any results on that page as it's missing the search criteria to display the search results.
    I tried to change the form and include an "action" that would change the URL to include the search value but I can't include the input value as it's dynamic.
    For example with the below form if I enter any value into the input the URL updates to following: /image-search.aspx?search=otbra&page= It's missing the entered number of the input value.
    Search form with onchange and action and method post attributes:
      <xsl:attribute name="method"> <xsl:text>post</xsl:text> </xsl:attribute>
      <xsl:attribute name="action"> <xsl:text>?search=</xsl:text> <xsl:value-of select="$search"/><xsl:text>&amp;</xsl:text>page= (input value)</xsl:attribute>
    Is there some javascript or some way of detecting the value submitted and parsing it into the search string of the URL?
    Any assistance would be appreciated. Cheers, JV
