umbraco v 4.7.1.1
I can not find out how I make a test on whether my field is empty and if not then insert an image
at <!--- menuThumbnail -->
field menuThumbnail
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets "><xsl:output method="xml" omit-xml-declaration="yes"/><xsl:param name="currentPage"/><xsl:param name="mediaFolder" select="$currentPage/menuThumbnail" /> <!-- update this variable on how deep your site map should be --><xsl:variable name="maxLevelForSitemap" select="4"/><xsl:template match="/"> <xsl:call-template name="drawNodes"> <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@isDoc and @level=1]"/> </xsl:call-template></xsl:template><xsl:template name="drawNodes"> <xsl:param name="parent"/> <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)"> <xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1' and @level <= $maxLevelForSitemap]"> <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1' and @level <= $maxLevelForSitemap]) > 0"> <xsl:call-template name="drawNodes1"> <xsl:with-param name="parent" select="."/> </xsl:call-template> </xsl:if> </xsl:for-each> </xsl:if></xsl:template> <xsl:template name="drawNodes1"> <xsl:param name="parent"/> <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)"> <xsl:text disable-output-escaping="yes"><div id="</xsl:text><xsl:value-of select="@urlName"/><xsl:text disable-output-escaping="yes">" style="visibility:hidden;" onMouseOver="show('</xsl:text><xsl:value-of select="@urlName"/><xsl:text disable-output-escaping="yes">')" onMouseOut="hide('</xsl:text><xsl:value-of select="@urlName"/><xsl:text disable-output-escaping="yes">')" class="undermenu"></xsl:text> <xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1' and @level <= $maxLevelForSitemap]"> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> <xsl:if test="menuThumnail !=''"> </xsl:if> <!-- menuThumbnail --> <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1' and @level <= $maxLevelForSitemap]) > 0"> <xsl:call-template name="drawNodes"> <xsl:with-param name="parent" select="."/> </xsl:call-template> </xsl:if> </xsl:for-each> <xsl:text disable-output-escaping="yes"></div></xsl:text> </xsl:if> </xsl:template> </xsl:stylesheet>
Upload image
test and inset images if is not empty menuThumbnail
umbraco v 4.7.1.1
field menuThumbnail
<xsl:stylesheet
version="1.0"
</xsl:template>
</xsl:if>
</xsl:for-each>
</xsl:if>
</xsl:template>
</a>
</xsl:if>
</xsl:if>
</xsl:for-each>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
