  • Nicklas Fagerkvist 1 post 21 karma points
    Dec 19, 2012 @ 21:57
    Nicklas Fagerkvist
    General newssection
    Hi, I have a problem to with a general news section.
    My structure looks like this:
    Root
    - General news
    - News article
    - Customer portal 1
    - Customer news
    - News article
    - - Customer portal 2
    - Customer news
    - News article
    I have no problem to list the news from both general news and customer news on the customer portal page.
    But the URL to the general news article points to url above customer portal, but I want it to act as it where on the customer portal page.
    My xlst looks like this,
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
      xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:PS.XSLTsearch="urn:PS.XSLTsearch"
      exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets PS.XSLTsearch ">
    <!-- Don't change this, but add a 'contentPicker' element to -->
    <!-- your macro with an alias named 'source' -->
    <xsl:variable name="source" select="/macro/source"/>
    <xsl:variable name="source2" select="1153"/>
    <xsl:template match="/">
      <h1>Aktuell information</h1>
    <!-- The fun starts here -->
    <table width="350">
      <xsl:for-each select="umbraco.library:GetXmlNodeById($source)/* [@isDoc and string(umbracoNaviHide) != '1'] | umbraco.library:GetXmlNodeById($source2)/* [@isDoc and string(umbracoNaviHide) != '1']">
        <xsl:sort select="umbraco.library:FormatDateTime(@updateDate,  'yyyy-MM-dd hh:mm')" order="descending" />
      <tr>
        <td><xsl:value-of select="umbraco.library:FormatDateTime(@createDate,  'yyyy-MM-dd')"/></td>
        <td><a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a></td>
        <td>(<xsl:value-of select="nyhetsavsandare"/>)</td>
      </tr>
    </xsl:for-each>
      </table>
    </xsl:template>
    </xsl:stylesheet>
    Is the anyone out there who could help me to get the xlst right?
    Nicklas
