  • Molly 94 posts 134 karma points
    Feb 05, 2013 @ 19:11
    Molly
    XSLT Variable select not displaying Home node data type on uBlogsy levels beyond landing page
    I have an xslt file that selects a folder from media and displays it as a slideshow on everypage bar the homepage of the site i am building. This media folder is selected on the home section by the user, the slideshow displays fine on every page using :
     <xsl:variable name="slideImages" select="$currentPage/ancestor-or-self::*/Home/slideImages" />
    I have uBlogsy integrated into the site and the slideshow displays fine on the landing page of uBlogsy but if i click into the post the slideshow goes from url:
    to:
    it's trying to access the media folder from the level above rather than going back to the root. I've tried various different variable selects with no success.
    Any help would be appreciated.
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Feb 12, 2013 @ 22:53
    Hi Molly,
    If I understand you correct, you should be able to just say:
    <xsl:variable name="slideImages" select="$currentPage/ancestor-or-self::Home/slideImages" />
    Which means to go up until a "Home" document type is found, and then take the slideImages off of that.
    (If this is not right, please post a screenshot or similar of the structure in uBlogsy, and I'll fix the XPath for you.)
    /Chriztian
    Feb 13, 2013 @ 19:03
    Molly
    Great that worked, before this i got it working using the home node specifically :
    umbraco.library:GetXmlNodeById(1048)/slideImages
    But i prefer not to use the node id to do this.
    Thank you
