Hi all, I am currently upgrading our website from umbraco 4.0 to 6.0. I have some code that I have run through the converter I found at http://blackpoint.dk/umbraco-workbench/tools/convert-xml-schema-to-45-.aspx?p=2 but it still does not want to work.
The old code I used was <xsl:value-of select="$source/node/data [@alias = 'bodyText']" disable-output-escaping="yes"/>
The code it changed it to is
<xsl:value-of select="$source/node/bodyText" disable-output-escaping="yes"/>
This does not pull anything back, the only way I can get it to pull anything back is to use<xsl:value-of select="$source" disable-output-escaping="yes"/>
Which pulls back more than just bodyText obviously. I can't find a way to get it to only pull through the contents of bodyText.
Any help is greatly appreciated.
Hi Simon,
You should use this instead:
<xsl:value-of select="$source/*[@isDoc]/bodyText" disable-output-escaping="yes" />
Note that no matter how many documents you have below $source, only the first will be output (but that was the same with the original, so... :)
/Chriztian
Hi Chriztian, thanks for the fast response. That works for me now, thanks so much!
New schema problem with macro
Hi Simon,
/Chriztian
