  • Claushingebjerg 939 posts 2574 karma points
    Sep 01, 2009 @ 09:47
    Claushingebjerg
    a bit of syntax help
    i have a variable:
    <xsl:variable name="numberOfRecords" select="count($currentPage/node)"/>
    But i would like it to test and only count the nodes where "date"  is greater than Currentdate. Like:
    (umbraco.library:FormatDateTime(data[@alias='date'],'yyyyMMdd') &gt;= umbraco.library:FormatDateTime(umbraco.library:CurrentDate(),'yyyyMMdd'))
    How do i combine the two into one?
    Sep 01, 2009 @ 10:04
    Dirk De Grave
    Hi Claushingebjerg,
    You're pretty close, just add the restriction as in:
    <xsl:variable name="numberOfRecords" select="count($currentPage/node [umbraco.library:FormatDateTime(data[@alias='date'],'yyyyMMdd') &gt;= umbraco.library:FormatDateTime(umbraco.library:CurrentDate(),'yyyyMMdd'))])"/>
    Hope this helps.
    Regards,
    /Dirk
  • horsted 74 posts 136 karma points
    Sep 01, 2009 @ 10:43
    horsted
    Hi Dirk and other xslt-wizards,
    I (like Claus? :-) often have problems using/understanding restrictions when choosing nodes, and I tend to end up doing a 'for-each' with an 'if' instead to get the diseried nodes. I alwasy have a feeling, that it could have been made much simpler with restrictions, like in your example, so a Wiki explaning the syntax and some good example would help a lot of people i think :-) So hoping someone would take the time to write one...
    Thanks in advance!
    Cheers, horsted
