I had a script running perfect in Umbraco 4.8.1 but when I upgraded to 4.9.1, I get an error:
Error occured
System.Xml.Xsl.XslTransformException: Cannot find a script or an extension object associated with namespace 'urn:Exslt.ExsltStrings'. at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args) at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, XPathNavigator {urn:schemas-microsoft-com:xslt-debug}current) at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime) at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime) at Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime) at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlSequenceWriter results) at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer) at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, XmlWriter results, XmlResolver documentResolver) at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results) at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
I have followed the instructions for upgrading and all other XSLT's are working fine. It's just the one that uses Exslt.ExsltStrings that doesn't work. Did I forget something? Is there something I can do to fix this?
Problem using Exslt.ExsltStrings?
Hi!
I'm using the Exstl.ExsltStrings to convert values in a script to lowercase. Like this:
<xsl:value-of select="Exslt.ExsltStrings:lowercase($currentPage/@nodeName)" />I had a script running perfect in Umbraco 4.8.1 but when I upgraded to 4.9.1, I get an error:
Error occured
Thanks in advance!
/Thomas
Not a proper solution, but when I continued the upgrade process and got to version 4.11.5, the problem disappeared.
