I hope someone can help me with this problem. I have a page where I want to have a div, and inside that div another div which is suppose to run 4 times, like this:
Thanks for your answer, I did find this solution when searching. However I do not understand it totally. I have tryed to change something, but nothing seems to chance on my page. It seems like my situation is a bit different, which may be why I do not understand it.
I have a overview-page, which has x number of children. This overview-page have to get some properties from these childs. Is that how this code works too?
The basis problem is I not understand everything, basicly what is going on on every step. I have only worked with umbraca for 3 weeks now, and this kode snippet is a bit advance for me to understand. This gives me a problem with replacing the right context with my stuff.
eg. this bit:
!-- Grab the data to output -->
<xsl:variable name="nodes">
<xsl:copy-of select="$root//*[@nodeType = 1074][not(umbracoNaviHide = 1)]" />
</xsl:variable>
Does this mean that at the nodeID (Is nodetype = nodeID?) the result are places in a variable?
This I have no idea what does / what it is suppose to achieve?
Then there are 3 parts which is worked around the "apply-template" coding, which I have never work with. I read some stuff about if, but is in generel not sure how it works.
<xsl:template match="/">
<!-- Apply templates to every third document, starting with the first -->
<xsl:apply-templates select="$data/*[position() mod 3 = 1]" mode="row" />
</xsl:template>
<!-- Template to start a row -->
<xsl:template match="*[@nodeType = 1074]" mode="row">
<div class="row">
<!-- Now render this document and the following 2 -->
<xsl:apply-templates select=". | following-sibling::*[@nodeType = 1074][position() < 3]" mode="col" />
</xsl:template>
<!-- Template for a column -->
<xsl:template match="*[@nodeType = 1074]" mode="col">
<div class="col">
<!-- Redefine class for every third item -->
<xsl:if test="position() mod 3 = 0">
<xsl:attribute name="class">col last</xsl:attribute>
</xsl:if>
<xsl:value-of select="@nodeName" />
</xsl:template>
Here's something that should work as a sample for you - feel free to ask about the specifics of this one:
<xsl:stylesheet
version="1.0"
exclude-result-prefixes="umbraco.library"
<xsl:output method="xml" indent="yes" omit-xml-declaration="yes" />
<xsl:param name="currentPage" />
<xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::*[@level = 1]" />
Grab all the nodes you need to render - you can do this in many ways,
this assumes they are all of the document type Artikel and that they are
children of currentPage:
<xsl:variable name="nodes" select="$currentPage/Artikel[not(umbracoNaviHide = 1)]" />
<!-- How many should be grouped together? -->
<xsl:variable name="groupSize" select="4" />
<!-- Apply templates to all the "first" Artikel nodes in each group in "wrapper" mode -->
<xsl:apply-templates select="$nodes[position() mod $groupSize = 1]" mode="wrapper" />
</xsl:template>
<!-- Template to start a group -->
<xsl:template match="Artikel" mode="wrapper">
<div class="product_oversight">
<!-- Now process this Artikel and the following in the same group, in "item" mode -->
<xsl:apply-templates select=". | following-sibling::Artikel[position() < $groupSize]" mode="item" />
</xsl:template>
<!-- The actual rendering template for an Artikel -->
<xsl:template match="Artikel" mode="item">
<div class="product_brief">
<img src="{oversigtsbilled}" />
<p class="product_title"><xsl:value-of select="oversigtTitle" /></p>
<p><xsl:value-of select="oversigtTeaser"/></p>
<a href="{umbraco.library:NiceUrl(@id)}">Læs mere</a>
</xsl:template>
</xsl:stylesheet>
Div inside div for every 4 chiild
Hallo everyone,
<div1> <div2> something </div2> <div2> something </div2> <div2> something </div2> <div2> something </div2> </div1> <div1> .....I have got this so far, but no idea how to finish it off:
<xsl:for-each select="$currentPage/* [@isDoc and string(umbracoNaviHide) != '1']"> <div class="product_oversight"> <xsl:if test="position() <= 4"> <div class="product_brief"> <img> <xsl:attribute name="src"> <xsl:value-of select="oversigtsbilled" /> </xsl:attribute> </img> <p class="product_title"><xsl:value-of select="oversigtTitle" /></p> <p><xsl:value-of select="oversigtTeaser"/></p> <a href="{umbraco.library:NiceUrl(@id)}">Læs mere</a> </div> </xsl:if> </div> </xsl:for-each>I am well aware that this is only running 4 times, but I have no idea how to get the last part to work.
Help pls! Thanks in advance.
See Toms or Chriztians post here http://our.umbraco.org/forum/developers/xslt/12819-Adding-div-around-every-3rd-item-returned-from-GetXmlAll()
Hi Matias,
I search the forum for similar posts on the subject.
And I think you can find inspiration or use Chriztian Steinmeier answers.Chriztian is really good at XSLT.
http://our.umbraco.org/forum/developers/xslt/11527-Problem-with-listing-HTLM-strcuture-with-XSLT
Hope it can help you out.
/Dennis
Hallo both of you,
Hey Matias,
You have to let us know which bit you're having problems with.
The solution we posted a link to show's you how to determine when to open / close DIV's so you can have every 4th one closed.
Listing the children is a different question.
However to answer your question, the answers we linked to are generic.
Rich
Hi Matias,
I think you need to show us the actual output you want, e.g., is it something like this: ?
<div class="product_oversight"> <div class="product_brief">...</div> <div class="product_brief">...</div> <div class="product_brief">...</div> <div class="product_brief">...</div> </div> <div class="product_oversight"> <div class="product_brief">...</div> <div class="product_brief">...</div> <div class="product_brief">...</div> <div class="product_brief">...</div> </div>/Chriztian
eg. this bit:
!-- Grab the data to output --> <xsl:variable name="nodes"> <xsl:copy-of select="$root//*[@nodeType = 1074][not(umbracoNaviHide = 1)]" /> </xsl:variable>Does this mean that at the nodeID (Is nodetype = nodeID?) the result are places in a variable?
<!-- Enable XPath selection in nodes --> <xsl:variable name="data" select="make:node-set($nodes)" />Then there are 3 parts which is worked around the "apply-template" coding, which I have never work with. I read some stuff about if, but is in generel not sure how it works.
<xsl:template match="/"> <!-- Apply templates to every third document, starting with the first --> <xsl:apply-templates select="$data/*[position() mod 3 = 1]" mode="row" /> </xsl:template> <!-- Template to start a row --> <xsl:template match="*[@nodeType = 1074]" mode="row"> <div class="row"> <!-- Now render this document and the following 2 --> <xsl:apply-templates select=". | following-sibling::*[@nodeType = 1074][position() < 3]" mode="col" /> </div> </xsl:template> <!-- Template for a column --> <xsl:template match="*[@nodeType = 1074]" mode="col"> <div class="col"> <!-- Redefine class for every third item --> <xsl:if test="position() mod 3 = 0"> <xsl:attribute name="class">col last</xsl:attribute> </xsl:if> <xsl:value-of select="@nodeName" /> </div> </xsl:template>Hi Christian,
My Content section looks like this:
product Artikel1 Artikel2 ...Inside each artikel, there are some parameter which I would like to take out and use in the template for product.
You are right my ending html is suppose to look like this.
<divclass="product_oversight">
<divclass="product_brief">...</div>
Inside each <div class="product_brief">
<img> <xsl:attribute name="src"> <xsl:value-of select="oversigtsbilled" /> </xsl:attribute> </img> <p class="product_title"><xsl:value-of select="oversigtTitle" /></p> <p><xsl:value-of select="oversigtTeaser"/></p> <a href="{umbraco.library:NiceUrl(@id)}">Læs mere</a>Hi Matias,
<?xml version="1.0" encoding="UTF-8"?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="umbraco.library" > <xsl:output method="xml" indent="yes" omit-xml-declaration="yes" /> <xsl:param name="currentPage" /> <xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::*[@level = 1]" /> <!-- Grab all the nodes you need to render - you can do this in many ways, this assumes they are all of the document type Artikel and that they are children of currentPage: --> <xsl:variable name="nodes" select="$currentPage/Artikel[not(umbracoNaviHide = 1)]" /> <!-- How many should be grouped together? --> <xsl:variable name="groupSize" select="4" /> <xsl:template match="/"> <!-- Apply templates to all the "first" Artikel nodes in each group in "wrapper" mode --> <xsl:apply-templates select="$nodes[position() mod $groupSize = 1]" mode="wrapper" /> </xsl:template> <!-- Template to start a group --> <xsl:template match="Artikel" mode="wrapper"> <div class="product_oversight"> <!-- Now process this Artikel and the following in the same group, in "item" mode --> <xsl:apply-templates select=". | following-sibling::Artikel[position() < $groupSize]" mode="item" /> </div> </xsl:template> <!-- The actual rendering template for an Artikel --> <xsl:template match="Artikel" mode="item"> <div class="product_brief"> <img src="{oversigtsbilled}" /> <p class="product_title"><xsl:value-of select="oversigtTitle" /></p> <p><xsl:value-of select="oversigtTeaser"/></p> <a href="{umbraco.library:NiceUrl(@id)}">Læs mere</a> </div> </xsl:template> </xsl:stylesheet>/Chriztian
Thanks Chriztian!
It works like a charm and I think I understood most of it too. Very nice comment and understanding code!
