  • Johan Roug 97 posts 153 karma points
    Sep 03, 2009 @ 21:57
    Johan Roug
    using xslt to display campaigns
    I have the following tree
    • content
    • Kampagner
    • campaign01
    • campaign02
    each campaign in this folder have 3 fields (alias names: campaignHeader, campaignText, campaignImage)
    on a normal page which is on the same level as "Kampagner", I use the ultimate picker to display all campaigns.The alias name is "campaignss" THe editor can then choose via checkboxes what campaigns should be shown on the page. Or this is the way I want it to function
    can anyone help me out? I have tried a lot, and I can make the ID show, sometimes the content.. but I am getting blind on the code
    I use something like
    <xsl:variable name="pageCamp" select="$currentPage/data [@alias = 'campaigns']"/>
    <xsl:for-each select="$pageCamp">
               <xsl:if test="$currentPage/data [@alias = 'campaigns'] ">
                          <h2>
                               <xsl:value-of select="$pageCamp"/>
                          </h2>
                          <p>
                                     <xsl:value-of select="$currentPage/ancestor-or-self::node [@level = '1']/following::node/data [@alias = 'campaignHeader']"/>
                          </p>
               </xsl:if>
    </xsl:for-each>
    Sep 03, 2009 @ 22:16
    Johan Roug
    <!-- /* Font Definitions */ @font-face {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0; mso-font-charset:2; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:0 268435456 0 0 -2147483648 0;} @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-520092929 1073786111 9 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:612.0pt 792.0pt; margin:3.0cm 2.0cm 3.0cm 2.0cm; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} /* List Definitions */ @list l0 {mso-list-id:1004820704; mso-list-type:hybrid; mso-list-template-ids:-1395331246 67502081 67502083 67502085 67502081 67502083 67502085 67502081 67502083 67502085;} @list l0:level1 {mso-level-number-format:bullet; mso-level-text:; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-18.0pt; font-family:Symbol;} @list l0:level2 {mso-level-number-format:bullet; mso-level-text:o; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-18.0pt; font-family:"Courier New";} @list l0:level3 {mso-level-number-format:bullet; mso-level-text:; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-18.0pt; font-family:Wingdings;} ol {margin-bottom:0cm;} ul {margin-bottom:0cm;} -->
    I have the following structure
    • Content
      • Home
        • Page
    • Kampagner
      • Campaign01
      • Campaign02
    On the campaign documents I have 3 fields (alias names: campaignHeader, campaignText, campaignImage). On page like home and page, I have the option to choose which campaign I want on either page. I can choose them with checkboxes.
    So if I have 4 campaigns but only 2 is selected on a page, there should only be rendrede 2 on that page.
    I have tried to make some XSLT which does this, but it doesn’t quite do the job. Can someone help?
                          <h2>
                          </h2>
                          <p>
                          </p>
               </xsl:if>
    </xsl:for-each>
    Sep 04, 2009 @ 12:09
    dandrayne
    HI there
    I attempted to answer this here -> http://our.umbraco.org/forum/developers/xslt/3924-using-xslt-to-display-campaigns
    Good luck!
