  • Ivan 165 posts 543 karma points
    Mar 26, 2013 @ 08:20
    Ivan
    RenderMacroContent. How do I output RTE content in macro?
    Hi everybody.
    There're 2 xslt templates:
    1) RenderAll.xslt - outputs all content on the page depending on what macros have been selected.
    2) RenderNews.xlst - outputs news list.
    The structure is as follows:
    RenderAll.xslt
    <xsl:value-of select="umbraco.library:RenderMacroContent('selector', $currentPage/@id)" />
    This piece of code gives empty string. Why?
    RenderNews.xslt
    <xsl:value-of select="umbraco.library:Item($currentPage/@id, 'textRTE')" />
  • Fuji Kusaka 2203 posts 4220 karma points
    Mar 26, 2013 @ 09:03
    Fuji Kusaka
    just call your property alias
    <xsl:value-of select="textRTE" disable-output-escaping="yes"/>
    Mar 26, 2013 @ 09:50
    Ivan
    In that case It's not possible to output macros via RTE.
    Mar 26, 2013 @ 11:36
    Fuji Kusaka
    Yes you can output your macros in your RTE. For this to work you need to go under Developer Section > Macros  > Choose your macros > Render content in editor
    Mar 26, 2013 @ 11:42
    Ivan
    Nope it doesn't work like that.
    umbraco.library:Item is used for the reason - to render macro that placed within RTE. Otherwise I would just just use pure <xsl:value-of select="rte" /> as you suggested.
    The problem is that umbraco.library:Item doesn' work properly when called via umbraco.library:RenderMacroContent.
    Mar 26, 2013 @ 12:00
    Fuji Kusaka
    Holy Crap.....its not Render in Content in Editor but "Use in editor"
    Mar 26, 2013 @ 13:20
    Ivan
    Same thing.
    <xsl:value-of select="rte" /> - works
    <xsl:value-of select="umbraco.library:Item(@id, 'rte') /> - doesn't work
    Any thought why the second variant doesn't work?
    Mar 26, 2013 @ 13:31
    Fuji Kusaka
    101
    What version of umbraco are you using btw ?
    This topic might help you
    Mar 26, 2013 @ 14:21
    Ivan
    Thanks, I'll check this one.
    Umbraco version is 4.11.1
    Apr 03, 2013 @ 19:57
    Ivan
    Thanks, Fuji.
    The following expression (from the topic you mentioned) did work for me and solved the problem:
    RenderNews.xslt
    <xsl:value-of select="umbraco.library:RenderMacroContent($currentPage/textRTE, $currentPage/@id)"/>
    Apr 03, 2013 @ 20:01
    Fuji Kusaka
    Hi Ivan,
    Great you got it working!!!! :)
