I have a more button which you can see below. The only problem is, if there's a page using the same name then it doesn't link accordingly. Could I add the "company" variable to the link structure at the end? I think that would fix it. :)
I think you might have something confused, if @id is a node id then there cannot be more than one node with the same name, so therefore it will be unique.
XSLT NiceUrl - Link help
Hi guys,
Hey Devin,
Rich
Hey Rich,
Take a look here.
https://www.res-group.com/what-we-do/advisory-services/case-studies.aspx
Carbon Reduction Strategy
There are two case studies with the same name, but they each use the "company" field which is added onto the Title.
The 2nd case study doesn't link correctly because it uses the same name as the other case study.
Please delete this thread, I fixed it.
Hey Devin,
It's more useful if you post your solution here and mark it as solved, so you might help others.
Rich
It was a very easy solution. I just renamed the node names. :)
Devin
