  • Colin Watson 17 posts 47 karma points
    Apr 29, 2013 @ 16:38
    Colin Watson
    xslt for 3 level dropdown menu
    Hi, Im new to Umbraco and this forum. Can anybody give me the xslt code for a 3 level menu like the below or point me in the right direction where I can find it. Or should I be using Superfish instead?
    Thanks in advance.
    Colin Watson
    <ul class="menuH decor1">
    <li><a href="projects.html" class="arrow">Projects</a>
                  <ul>
                    <li><a href="projects.html" class="arrow">Residenial</a>
                      <ul>
                        <li><a>1</a></li>
                        <li><a>2</a></li>
                      </ul>
                    </li>
                 </ul>
            </li>
    <li><a href="#2" class="arrow">Contact us</a>
                  <ul>
                    <li><a class="arrow">Item 1</a></li>
                    <li><a class="arrow">Item 2</a></li>
                  </ul>
                </li>
    </ul>
    Apr 29, 2013 @ 21:40
    Dennis Aaen
    Hi Colin,
    I will try to help you or at least point you in the right direction.
    <xsl:template match="/">
    <xsl:variable name="level" select="2"/>
    <xsl:variable name="dropDown" select="3"/>
    <!-- The fun starts here -->
    <xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
      <li class="arrow">
        <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a>
         <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1']) &gt; 0">
           <ul>
                <xsl:for-each select="./* [@isDoc and string(umbracoNaviHide) != '1']">
                      <li class="arrow">
                    </a>
                </li>
                   </xsl:for-each>
           </ul>
         </xsl:if>
      </li>
    </xsl:for-each>
    </ul>
    </xsl:template>
    This should list level two nodes and if the level two nodes have any children these will be printed. You can change which levels of that should be printed by change these two lines.
    /Dennis
    Apr 30, 2013 @ 12:37
    Colin Watson
    Dennis thank you. I'll try this and get back to you.
    Best regards
    Colin
