  • shine 43 posts 83 karma points
    May 21, 2013 @ 15:50
    shine
    How to use direct current page namein xslt?
    Here is my code that i want to use direct Test page in my xslt but it did'n get any out put
    where is the problem in this syntax?
        <xsl:for-each select="$currentPage/ancestor-or-self::SiteRoot/ImageTest/imgcontent">
            <xsl:if test="$currentPage [name() = 'TEST']">
        {"url":"<xsl:value-of select="imagegallaery" />","width":"333","height":"249"}
        <xsl:if test="position() != last()">,</xsl:if>
            </xsl:if>
        </xsl:for-each>
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    May 21, 2013 @ 15:59
    Hi shine,
    When doing that, you're testing the XML element name (the Alias your document type gets) - if you're looking for the Name you give the page in Umbraco (i.e. what you see in the tree and on the Properties tab) use @nodeName :
    <xsl:if test="$currentPage[@nodeName = 'TEST']">
    </xsl:if>
    </xsl:for-each>
    /Chriztian
    May 21, 2013 @ 16:07
    shine
    hey chriztian
    TEST is my page name which is in my content of umbraco and i want to use direct name of content page in my xslt
