  • Dane Garcia 9 posts 70 karma points
    Jul 04, 2013 @ 21:41
    Dane Garcia
    Starting Site Map from Level 2
    Hello all, I'm trying to start a sitemap from level 2 and having some issues. I'm just using the standard site map template and chaning the param line for parent
    <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@isDoc and @level=1]"/>
    To:
    <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@isDoc and @level=2]"/>
    I get the following error:
    Error occured
    System.OverflowException: Value was either too large or too small for an Int32.
    at System.Convert.ToInt32(Double value)
    at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
    at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
    at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, IList`1 parent)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    Jul 04, 2013 @ 22:40
    Dennis Aaen
    Hi Dane,
    I have mde some small test on a local installation of Umbraco and I have not been able to find a solution. At the same time, I can see.some others have the same issue as you.http://our.umbraco.org/forum/developers/xslt/16663-Sitemap-from-level-2. I have search the forum to see if I could find some thing that could help to closer to a solution.
    In the post I mention above Dan solve the issue by using the package.Cogworks-flexible-navigation
    http://our.umbraco.org/projects/website-utilities/cogworks-flexible-navigation.
    I havn´t used it myself but you have the opportunity to select a start level and how deep it´s should go listing nodes.
    I hope this could be a solution for your problem.
    /Dennis
    Jul 05, 2013 @ 15:41
    Dane Garcia
    I was able to resolve my issue without the Cogworks-flexible-navigation. The solution is as follows:
    Changed:
    To:
    <xsl:with-param name="parent" select="umbraco.library:GetXmlNodeById(1144)"/>
    The 1144 is the node id of the home page I wished to start the site map from. You can obtain the node id of any page/media item by going to the properties tab in the back office, it will be titled "Id". Thanks for your suggestion though Dennis!
