  • Paul Griffiths 370 posts 1021 karma points
    Jul 05, 2013 @ 17:09
    Paul Griffiths
    Help with rendering images
    Hi guys im a complete newbie with xslt but im wondering if anyone could help me.
    I have an perfectly good xslt macro that renders a news list like so
    <!-- The fun starts here -->
    <ul>
    <xsl:for-each select="$currentPage/* [@isDoc]">
        <xsl:sort select="@createDate" order="descending"/>
        <xsl:if test="position() &lt;= $maxItems">
        <li>
            <h3>
                <xsl:value-of select="pageImage"/>   <---------------------------------
                <xsl:value-of select="newsHeadline"/>
                </a>
            </h3>
            <p><xsl:value-of select="newsTeaserText" /></p>
            <small>Created by: <xsl:value-of select="@writerName"/> on <xsl:value-of select="umbraco.library:LongDate(@createDate)"/> </small>
        </li>
        </xsl:if>
    </xsl:for-each>
    However im trying to render an image into the produced list that has the alias pageImage. I add the line of code that I have bolded and marked with an arrow and instead of an image rendering i get this.../media/1004/luis.jpg
    I just thought it would be a case of adding xsl:value of similar to how i have targeted other umbraco page fields.
    Thanks for the help in advance
    Paul
  • Niels Lynggaard 193 posts 551 karma points
    Jul 05, 2013 @ 17:57
    Niels Lynggaard
    use umbraco.library:getmedia() like this:
    <xsl:variablename="media"select="umbraco.library:GetMedia($currentPage/pageImage, 0)"/>
    <xsl:iftest="$media">
    <xsl:variablename="url"select="$media/umbracoFile"/>
    <xsl:variablename="width"select="$media/umbracoWidth"/>
    <xsl:variablename="height"select="$media/umbracoHeight"/>
    <imgsrc="{$url}"width="{$width}"height="{$height}"/>
    </xsl:if>
    Depending on what version of the schema your're using the syntax is a little different.
    Check out the docs here:
    http://our.umbraco.org/wiki/reference/umbracolibrary/getmedia
    Jul 05, 2013 @ 20:50
    Paul Griffiths
    Thanks for your reply niels, I will give it a go and let you know how I do
    Paul
