I am currently working with Umbraco 4.0.4.2 (i know really old, it will be updated in the future) and i wanted to add a checkbox to the newsitem pages so the editors can add social media buttons to the page where they would like to have them.
Now my problem is that i thought i had solved it by making a xslt macro that gets the checkbox and if it is 1 then add the div with the social media items to the page. this is my xslt script:
So i checked if it was 1 (checked) and if it is then just show the div. but the variable is empty. My question was, why is it empty in the first place? I already checked my alias 2 times so that isn't the problem
This may be a stupid question on my behalf but did you hit "Save and publish" on the node, on which you're testing? If so do you see a value on the node if you have a look in the /data/umbraco.config file and search for "addSocialMediaButtons"? - If it has a value of 1 in there then it must be something in the syntax but at a first glance it looks fine to me.
It's not a stupid question but yes i had hit save and publish on the node. I also tried to print a value to maybe see if it returned 0 but that didn't work either. I can't reach the config file from my location at this point yet but tomorrow i probably will so i will have a look at that then. It's really confusing to me because it is just a simple check if the checkbox is checked. It seems to not find the checkbox at all.
ok I solved it but I didn't see how i fixed it. All I did was copy an existing xslt template and edited that to what i already had. so basically didn't change anything and now it works.
So yea i have no idea what actually went wrong in the first place but thanks for helping!
problem with a small xslt checkbox check
Hello guys!
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
<xsl:template match="/">
<xsl:variable name="buttons" select="string($currentPage/data [@alias='addSocialMediaButtons'])" />
<xsl:if test="string($buttons) = '1'" >
<div id="TestSocialMedia">
<br/><br/>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Any suggestions in how to fix this easy problem?
Keep in mind that this is 4.0.4.2
Thanks in advance!
Hi Stef and welcome to our :)
Looking forward to hearing from you.
Hello Jan!
thank you for your reaction.
Hi Stef
Glad to hear you managed to got it working - Even if it means it was magic ;-)
Happy umbracoing.
