That seems perfectly reasonalbe to me, you just need to put some logic in the <xsl:for-each> blocks (and then close them). I would recommend using an <xsl:template> to combine the code so you only have to write it once...
<xsl:template name="doSomething"><!-- This just prints the nodeName of item --> <xsl:param name="item"/> <p><xsl:value-of select="$item/@nodeName"/></p> </xsl:template> </xsl:stylesheet>
Choose and For-each
A stupid question I am sure, but here is what I am trying to do:
<xsl:choose> <xsl:when test="$prev_dates=1"> <xsl:for-each select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1' and(umbraco.library:FormatDateTime(data[@alias='dato'],'yyyyMMdd') >= umbraco.library:FormatDateTime(umbraco.library:CurrentDate(),'yyyyMMdd'))]"> </xsl:when> <xsl:otherwise> <xsl:for-each select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1' and(umbraco.library:FormatDateTime(data[@alias='dato'],'yyyyMMdd') < umbraco.library:FormatDateTime(umbraco.library:CurrentDate(),'yyyyMMdd'))]"> </xsl:otherwise> </xsl:choose>.. I know this doesnt work, but what are the proper method to do this in XSLT?
Thanks in advance!
Great, thanks!!
