  • Jonas Eriksson 930 posts 1825 karma points
    Sep 30, 2009 @ 06:58
    Jonas Eriksson
    create a un-closed un-escaped <body>-tag
    Hi! I would like to create and use a macro that inserts a unclosed body-tag with a class-attribute into my templates.
    <body class="conditional classes">
    I like to have a separate macro for this since several other macros as well as html are building up the rest of the templates.
    I can not get it to work. I tried to use cdata to produce my output, but that is escaped to &lt;body ... &gt;, and when I tried <xsl:text disable-output-escaping="yes"><![CDATA[ <body class="members"> ]]></xsl:text> I got nothing?
    Thanks!
  • Mikael Mørup 297 posts 326 karma points
    Sep 30, 2009 @ 08:41
    Mikael Mørup
    I think something like:
         <body>
               <xsl:attribute name="class">conditional classes</xsl:attribute>
    should do it.
    Mikael
    Sep 30, 2009 @ 09:15
    Jonas Eriksson
    Hm, yes, but that won't work since the </body> is missing, and the xslt-parser will give me an error. Or am I missing something here?
    Sep 30, 2009 @ 09:16
    Jonas Eriksson
    I just found out about inline xslt in template page fields, and I'm trying to use that approach.
  • Ron Brouwer 273 posts 768 karma points
    Sep 30, 2009 @ 09:18
    Ron Brouwer
    u can use somthing like this <!DOCTYPE xsl:stylesheet [ <!ENTITY body "&lt;body class=&quot;YourClass&quot;&gt;"> ]>
    And then use &body;
    Ron
    Sep 30, 2009 @ 09:38
    Mikael Mørup
    Yuo are right, the XSLT parser don't like missing closing tags.
    Jonas Eriksson
    Thanks for that advice, but then I get an error from umbraco.macro.loadMacroXSLT
    Unexpected token '<' in the expression --><<-- body class="members">
    I read somewhere else that runat=server in the template tag causes this. But the macro should be inside an contentplaceholder so I need the runat=server afaik.
    And inline xslt in template page fields does not seem to work with <xsl:if> or <xsl:choose> should it?
    Sep 30, 2009 @ 11:01
    Jonas Eriksson
    In my template I just would like to get a value from a xslt from within a tag:
    <body class="{call xslt to get class names}">
    The thing is that I use the same master template from several templates, many templates are used on both member and non-member pages. And we have different classes for the body on member and non-member pages. Phew... :-)
    Sep 30, 2009 @ 12:09
    Jonas Eriksson
    I do not know what I missed but this works:
    <body class="<umbraco:Macro Alias='BodyClassMacro' runat='server'></umbraco:Macro>">
    Sep 30, 2009 @ 12:12
    Jonas Eriksson
    And my xslt looks like this:
    <xsl:if test="count($currentPage/ancestor-or-self::node[@id = $memberBranchStartNode])=1">memberclass</xsl:if>
    Problem solved, thanks for your input.
