  • Gary 40 posts 129 karma points
    Aug 14, 2013 @ 13:03
    Gary
    Help with tagsLib:getAllTagsInGroup please!
    I have a number of tag groups which are displaying the tags correctly.
    My Issue is when the tags are clicked, I can't get the list of results to display.
    The code to generate the list of tags (which works) is this
    <xsl:if test="$currentPage/descendant-or-self::*/parent::*[@isDoc and @parentID='4253']">
            <xsl:if test="count(tagsLib:getAllTagsInGroup('tagsGroup1')//tag) > 0">
                <div class="ssnSubNode" style="background-color:#2484c6"><strong>Tag Group 1 Title</strong><img src="/media/276398/iconcctag.gif" class="ssnInfoIco"/></div>
                <ul>
                    <xsl:for-each select="tagsLib:getAllTagsInGroup('tagsGroup1')//tag">
                        <li style="padding:7px 0 0 10px;"><a href="tagResults?tag=(.)"><xsl:value-of select="."/></a> (<xsl:value-of select="@nodesTagged"/>)</li>
                    </xsl:for-each>
                </ul><br/>
            </xsl:if>
        </xsl:if>
    Im Using this code to generate the list of results but its not working.
    <xsl:variable name="nodeName" select="$currentPage/child::*/website//alias"/>
            <xsl:for-each select="$nodeName/*[@isDoc and (umbraco.library:Request('tag') = '' or contains(tags,umbraco.library:Request('tag')))]">
                <p><a href="{umbraco.library:NiceUrl(@id)}" ><xsl:value-of select="@nodeName"/></a></p>
            </xsl:for-each>
    Does anyone have any idea where i'm going wrong or can lend any guidance on this?
    Any help is much appreciated.
    Aug 14, 2013 @ 14:16
    Dennis Aaen
    Hi Gary,
    One thing I notice is that you are looping over tags, thats are empty, if I understands your code correctly. DonĀ“t know if this is supposed.
    Maybe you could try this and see if you have more luck with this.
    <xsl:variablename="nodeName"select="$currentPage/child::*/website//alias"/>
    <xsl:for-eachselect="$nodeName/*[@isDoc and (umbraco.library:Request('tag') !='' or contains(tags,umbraco.library:Request('tag')))]">
    <p><ahref="{umbraco.library:NiceUrl(@id)}"><xsl:value-ofselect="@nodeName"/></a></p>
    </xsl:for-each>
    /Dennis
    Aug 14, 2013 @ 14:53
    Gary
    Hi Dennis,
    thanks for taking the time to reply.
    I have just tried your suggestion but still nothing happens on the page where the results are supposed to be displayed.
    Many thanks
    Gary
