Comparing two sets of nodes and finding the unique nodes
So i need to list some subnodes from another node. The thing is, i only want to list the nodes that are NOT also picked on a MNTP on $currentPage.
I have a hunch i need to make a two node sets. One set of the subnodes, and one set of the nodes picked with the picker, and then compare these two with "contains()" somehow.
Well, the main reason is probably the usual for many developers: The fact that XSLT uses sets and is very efficient at manipulating those. If you've never done XSLT before (I know you have, though :-) you'd think you'd need to run through all items, checking the ids etc.
Here, you have a set of all the possible nodes (the $categories variable) and then you just ask for all of those that doesn't have an @id that's been picked in the MNTP property (sekundaartikler) - and that part works because, again, the $currentPage/sekundaartikler/MultiNodePicker//nodeId selects another set (containing nodeId nodes).
One tiny nit-pick I have: Unless your Artikel nodes are children of your Home node, you should rename the $siteRoot variable to something better, like $categoryRoot - because, well - just because :-)
If i want to list, lets say 8 nodes, ive done the following, but it doesnt really fly, as it takes the position regardless of the nodes we filteret out... So ti doesnt show 8 nodes, but less...
If you need to use position within the Artikel content, either move the contents of the template inside the for-each, or pass it along as a separate parameter, like this:
But of course i need to add another if statement, which f...s it up again :)
As im using this macro around the site based on a section selection on the article and section frontpage i need to use only the nodes who actually belong
Are we looking at adding a <xsl:with param... or am i on the wrong track?
For now im doing like this, but ágain, it returns less than 8 nodes because of <xsl:if test="contains (sektion, $currentPage/sektion)">
Well, you need to filter the nodes before you do the position() check - otherwise you'll end up with the same problem (getting 8 nodes but then filtering one or two of those out because of some condition).
So you'll need to add the check you're performing to the select you're doing in the for-each, but now it's a little too long so let's split it with a couple of variables:
<!-- Filter the categories to get rid of those picked in the MNTP -->
<xsl:variable name="unpicked" select="$categories[not(@id = $currentPage/sekundaartikler/MultiNodePicker//nodeId)]" />
<!-- Take the last 8 of those that match the current pages's "sektion" property -->
<xsl:for-each select="$unpicked[contains(sektion, $currentPage/sektion)]">
<xsl:sort select="@createDate" order="descending" />
<xsl:if test="position() < 9">
<xsl:apply-templates select=".">
<xsl:with-param name="pos" select="position()" />
</xsl:apply-templates>
</xsl:if>
</xsl:for-each>
But im a bit lost as how to get it set up.
Any help :) ?
Hi Claus,
Here's a scenario with Categories - you should be able to change what's needed for your own use:
/Chriztian
Hmmmm as alawys its not quite working out :|
Doing this renders the id's of the nodes picked with the picker...
Yeah - you need to point the
$categoriesvariable to the actual Artikel nodes, instead of the MultiNodePicker you're currently pointing to./Chriztian
Awesome, it works! not 100% sure i understand why it can be this easily though :)
For reference i ended up with:
Hehe :-)
$categoriesvariable) and then you just ask for all of those that doesn't have an @id that's been picked in the MNTP property (sekundaartikler) - and that part works because, again, the$currentPage/sekundaartikler/MultiNodePicker//nodeIdselects another set (containingnodeIdnodes).One tiny nit-pick I have: Unless your Artikel nodes are children of your Home node, you should rename the
$siteRootvariable to something better, like$categoryRoot- because, well - just because :-)/Chriztian
Thanks, that makes good sense.
A little bonus qusetion.
Hi Claus,
Yeah, that's the case where you need to use for-each instead :-)
You can keep the simple Artikel template, here's how:
for-each, or pass it along as a separate parameter, like this:/Chriztian
Awesome. We are sooooo close now :).
Alrighty :-)
/Chriztian
Beer on me!
I will collect that when we meet again :-)
