Hi, I search and try some examples to change my menu xslt file to support multilingual site but unsuccessfully.
I have a structure like
en
- Company news
- Page1
- Page2
- Company Blog
- Page3
- Page4
- PageAbout
pt
- Company news
- Page1
- Page2
- Company Blog
- Page3
- Page4
- PageAbout
My code always shows all the items from both languages on the menu.
Someone could help me to understand where I can change my code to support this?
Check this approach out - it uses the more idiomatic style XSLT was built for, which consist of separate templates for handling specific elements - you get very little duplication and you don't have recursively call a template - it's all built-in:
<?xml version="1.0" encoding="utf-8" ?>
<xsl:stylesheet
version="1.0"
exclude-result-prefixes="umbraco.library"
<xsl:output method="xml" indent="yes" omit-xml-declaration="yes" />
<xsl:param name="currentPage" />
<!-- Specify level of the top node for a language (usually 1) -->
<xsl:variable name="level" select="1" />
<!-- Grab the top node -->
<xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::*[@level = $level]" />
<xsl:template match="/">
<ul class="menu">
<!-- Create the Home link -->
<li>
<xsl:if test="$currentPage/@id = $siteRoot/@id">
<xsl:attribute name="class">sel</xsl:attribute>
</xsl:if>
<a href="/">
<xsl:value-of select="$siteRoot/@nodeName" />
</a>
</li>
<!-- Process all children of $siteRoot (if any) -->
<xsl:apply-templates select="$siteRoot/*[@isDoc][not(umbracoNaviHide = 1)]" />
</ul>
</xsl:template>
<!-- Generic template for all nav links -->
<xsl:template match="*[@isDoc]">
<li>
<xsl:if test="@id = $currentPage/@id">
</xsl:if>
<xsl:value-of select="@nodeName" />
</a>
<!-- Render sub menu if necessary -->
<xsl:call-template name="submenu" />
</li>
</xsl:template>
<!-- Template for Inactive links -->
<xsl:template match="*[@isDoc][umbracoNaviInactive = 1]">
<li>
</xsl:if>
<span>
</span>
<!-- Submenu? -->
</li>
</xsl:template>
<!-- Template checking for, and processing any submenu -->
<xsl:template name="submenu">
<xsl:variable name="subPages" select="*[@isDoc][not(umbracoNaviHide = 1)]" />
<xsl:if test="$subPages">
<ul>
<xsl:apply-templates select="$subPages" />
</ul>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
I've added some comments to explain what's going on, but feel free to ask about it - the only thing you may need to change is the $level variable if your "Home" nodes (i.e. the 'en' and 'pt' nodes) are not at level 1.
The trick lies solely in getting the $level variable right — because the XSLT goes up from $currentPage and stops at the level specified to find the root of the site. So if the level matches the level of the en or pt nodes, the navigation will always only show nodes within the current language/site.
If your Content tree looks like this:
Content
en
pt
— it should work as it is.
If you have another node before the languages, like this:
Content
Sites
en
pt
— you need to set the level to 2 instead.
You should not need to do anything else - you can (and should) use the exact same macro for all languages.
Hi again Chriztian
Can you help me with one more thing?
The Menu is working but now the issue is the Link to the homepage.
If I change the language from en to pt
When click at homepage link on pt language it change to the default en language, the first language.
How can I control the link on the homepage link?
What I miss to see?
Example
www.mysite.com when in pt should be www.mysite.com/pt/ but when click homepage returns always to www.mysite.com
Help with Menu on a multilanguage site
Hi, I search and try some examples to change my menu xslt file to support multilingual site but unsuccessfully. I have a structure like
My code always shows all the items from both languages on the menu. Someone could help me to understand where I can change my code to support this?
Hi Pedro,
$levelvariable if your "Home" nodes (i.e. the 'en' and 'pt' nodes) are not at level 1./Chriztian
Thank you for your answer. I tested you code and I have a doubt.
So when I change the language of the site, how he knows what node to show? Like changing "en" to "pt"? I need to change the level?
Hi Pedro,
$levelvariable right — because the XSLT goes up from$currentPageand stops at the level specified to find the root of the site. So if the level matches the level of the en or pt nodes, the navigation will always only show nodes within the current language/site.If your Content tree looks like this:
/Chriztian
Great, thank you so much.
Hi again Chriztian
What I miss to see?
Example
Hi Pedro,
Oh yes - of course.
You just need to call the
NiceUrl()extension with the$siteRootvariable:(Instead of the hardcoded "/" ...)
/Chriztian
Thank you again :)
Hi again,
I'm trying also to hide from the menu a specific document type (News Item) from the submenu
I try to use from XSLT Examples
[not(self::NewsItem)]
but I inserted on all matches but is all showing the news items on the menu.
How can I use this?
Hi Pedro,
There can be lots of reasons for them to be rendered anyway - can you post some more code so we can help you better?
/Chriztian
I'm using the code that you posted on September 17 to render the menu and using the Business Starter site pack
and tried this
I think i figure this out
use it like this
