I have used the Multilingual 1:1 sites tutorial to create a multilingual homepage for a website. I have it working in french and german but the default language just wont display!
Has anyone had a similar problem or can you help with this problem?
I have gone over the tutorial a few times to check that the xslt and language selector is correct and I can find no issues.
NOTE - this is resolved. Problem was the if statement checking whether a language code was detected in the URL. Removing this statement solved the issue
Help with Multilingual 1:1 sites
Hi all,
Any help would be greatly appreciated
(I can provide all the code if required)
Rog
