Hello
I have this made this sub menu script - I see no errors with it:
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets "> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:param name="currentPage"/> <xsl:param name="level"/> <xsl:template match="/"> <div id="sitemap"> <ul> <xsl:call-template name="drawNodes"> <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@level=1 and @isDoc]"/> </xsl:call-template> </ul> </div> </xsl:template> <xsl:template name="drawNodes"> <xsl:if test="count($currentPage/* [@isDoc and string(umbracoNaviHide) != '1']) > '0'"> <!-- The fun starts here --> <ul class="sidemenu"> <xsl:for-each select="$currentPage/* [@isDoc and string(umbracoNaviHide) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="siteTitle"/> </a> <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1']) > 0"> <ul> <xsl:call-template name="drawNodes"> <xsl:with-param name="parent" select="."/> </xsl:call-template> </ul> </xsl:if> </li> </xsl:for-each> </ul> </xsl:if> </xsl:template> </xsl:stylesheet>
When the script runs on a page, then the page does not respond, why is that?
Sub menu script - site not responding
Hello
