I have some xslt that either expand all or expand a level 3 node so the level 4 nodes are visible, but I want all the child nodes visible if there are any, so that if level 4 are visible and have child node they should be visible too. (I can change between the two with changing a 0 to 1).
The existing xslt is not something I wrote but something I have modified, and I'm not sure I understand enough to solve this... I really hope someone can help me!
I was thinking it should be someting like testing what level 1 node the active page(node) is under and then somhow get it to show all the childnodes to that level 1 node, but not the others...
I just don't know how or if the above can be done...
That should do what you are after. The only thing to watch out for is that you may need to have expandChildren="1" set to 0 on your homepage (otherwise it will just expand all the children of that particular node).
Yes just paste em to the bottom of you xslt for the menu, just before the end of the </stylesheet>, and call the menu in this template :<xsl:template match="/">
It's hard to tell why the navigation package is not working for you, without seeing your exact structure or exactly where and how you are inserting the macro.
I've just run a test here (with the structure I think you have) and all the children and grand children etc were shown.
The only things I can suggest are that you check that:
expandChildren="1"
and that
maxMenuDepth="999"
If you have some way of showing the exact structure and template code I can take a look and see if I can help further.
When I'm on a level 2 node all the level 3 nodes and childnodes are shown, but if I go to one of the level 3 nodes the other level 3 nodes isn't expanded anymore... only the one where I'm on a level 4 node...
In the above examples 1056 and 1053 are the IDs of the Leve 1 nodes. By settings these the navigation behaves as if it were on that page all the time. I realise this is a bit of a hack to get it to work and I think you'll be better off writing some custom XSLT (which if I get 5 mins I'll look to do).
This is a bit of a highjack of the thread but i can find the soln' anywhere else SORRY! (if you know where i might find it pls direct me. I am a newbie).... I want a very similar menu to Anette, and the cogworks package does 90% of what i need (its great thanks)...but what i would like to do is have the level one nodes display custom images for each menu item... the sub menu items would appear as text just as they do now...(Im trying to integrate a nice sprymenu js that I got from Dreamweaver) but i want to generate the content for the menu dynamically.
So what i need help with is the xslt code that will allow me to insert an <img> in between the <a></a> with a dynamic src to the image (based on the pagename) for only lvl 1 nodes and text for the rest of them.
If you haven't already found a possible solution I think that I have one for you... I used some code i found in the old umbraco forums.. works like a charm i was even able to insert my images...
The only thing it requires you to do is add a parameter for the starting node level. Use a content picker as part of the marco that you make and it will traverse all nodes from that point.
I have done this but my solution requires you to add the nav image to the pagenode for each new secton that you want. Let me know if this would help you.
Expanding menu help
I've a problem with a menu. Looks like this
Node level 3
- node level 4
- node level 4
- - node level 5
- - - node level 6
- - node level 5
Node level 3
Node level 3
- Node level 4
Here is the xslt:
<xsl:stylesheet
version="1.0"
<xsl:output method="html"/>
<xsl:variable name="maxLevel" select="5"/>
<xsl:variable name="minLevel" select="2"/>
<div id="navigationmenu">
<xsl:call-template name="drawNodes">
<xsl:with-param name="current" select="$currentPage/ancestor-or-self::node [@level=1]"/>
<xsl:with-param name="level" select="2"/>
<xsl:with-param name="openpage" select="$currentPage"/>
</xsl:call-template>
</xsl:template>
<xsl:template name="drawNodes">
<xsl:param name="current"/>
<xsl:param name="openpage"/>
<xsl:param name="level"/>
<xsl:param name="active">
<xsl:choose>
<xsl:when test="count($openpage/ancestor-or-self::node) > 0">
<xsl:call-template name="isInSubmenu">
<xsl:with-param name="list" select="$openpage/ancestor-or-self::node"/>
<xsl:with-param name="pos" select="1"/>
<xsl:with-param name="curpagename" select="$current/@id"/>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:param>
<xsl:if test="$active=1">
<ul>
<xsl:if test="$level = 1">
<li>
<a href="/" class="menu_level1">
<xsl:value-of select="$current/@nodeName"/>
</a>
</li>
</xsl:if>
<xsl:for-each select="$current/node [string(data [@alias='manual']) = '1']">
<li>
<xsl:choose>
<xsl:when test="@id=$openpage/@id">
<a href="{umbraco.library:NiceUrl(@id)}" class="selected">
<xsl:if test="@level >= '3'">
<xsl:for-each select="$currentPage/ancestor::node [@level > $minLevel and string(data [@alias='manual']) = '1']">
<xsl:value-of select="@sortOrder + 1"/>.</xsl:for-each><xsl:value-of select="$currentPage/@sortOrder + 1"/>.
</xsl:if>
<xsl:text> </xsl:text>
</a>
</xsl:when>
<xsl:otherwise>
<xsl:if test="@level = '3'">
<xsl:attribute name="class">
<xsl:text>menu</xsl:text>
</xsl:attribute>
</xsl:if>
<xsl:for-each select="./ancestor::node [@level > $minLevel and string(data [@alias='manual']) = '1']">
<xsl:value-of select="@sortOrder + 1"/>.</xsl:for-each><xsl:value-of select="./@sortOrder + 1"/>.
</xsl:if>
</a>
</xsl:otherwise>
</xsl:choose>
<xsl:with-param name="current" select="."/>
<xsl:with-param name="openpage" select="$openpage"/>
<xsl:with-param name="level" select="$level + 1"/>
</li>
</xsl:for-each>
</ul>
</xsl:if>
</xsl:template>
<xsl:template name="isInSubmenu">
<xsl:param name="list"/>
<xsl:param name="pos"/>
<xsl:param name="curpagename"/>
<xsl:variable name="curitemname" select="$list[$pos]/@id"/>
<xsl:choose>
<xsl:when test="$curitemname != $curpagename">
<xsl:choose>
<xsl:when test="$pos < count($list)">
<xsl:with-param name="list" select="$list"/>
<xsl:with-param name="pos" select="$pos + 1"/>
<xsl:with-param name="curpagename" select="$curpagename"/>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
</xsl:stylesheet>
I'm not 100% clear what you are trying to achieve.
Do you want to expand all nodes below a specific level 2 node (i.e. levels 3 and above)
For example:
Level 1 (not shown)
Level 2 (user is on this page, level 3, 4 and 5 are shown in the navigation) (not shown)
Level 3 (shown)
Level 4 (shown)
Level 5 (shown)
Level 3 (shown)
Level 4(shown)
Level 2 (not shown)
etc....
If so check out this package
Or are you after something more sophisticated?
T
Hi Tim, I have tried your package, but I can't get it to do what I want...
Hmm... I'll try to explain it better... I want all the level 1 shown all the time, but when a user click on a level 1 all the child levels are shown:
Level 1 (shown)
Level 1 (shown) <-- user is on this page
Level 2(shown)
Level 3 (shown)
Level 4 (shown)
Level 3(shown)
Level 2 (shown)
Level 2 (shown)
Level 1 (shown)
Level 2 (not shown)
Level 3 (not shown)
Level 1 (shown)
Level 2 (not shown)
Level 1 (shown)
etc...
I hope it's clearer now.
Anette
Some pointers would be nice.
Anette
Hi Anette
Please try add these templates:
And call the template with:
/Jacob
Here is the code: http://pastebin.com/d3fa7ca52
Hi Anette,
The package will support what you are trying to acheive:
<umbraco:Macro startingLevel="1" recurse="1" selectBranches="1" maxMenuDepth="999" ulBaseClass="" branchClass="" selectedClass="" forceNode="" expandChildren="1" forceHome="0" Alias="[COG]Navigation" runat="server"></umbraco:Macro>
T
Hi Jacob,
I'm not quite sure I understand what you mean I add these templates... where should I add them? To my existing xslt or a new one?
Anette
oops, please edit
<xsl:if test="ancestor-or-self::node[@level=2 and $currentPage/@id = descendant-or-self::node/@id] and ./node">
to use the $StartLevel parameter:
<xsl:if test="ancestor-or-self::node[@level=$StartLevel and $currentPage/@id = descendant-or-self::node/@id] and ./node">
Hi again,
Sorry for the wait but I couldn't test your code until today.
Jacob,
I put your code in my existing xslt, but it only shows the level 2 nodes with all the level 3 nodes visible not the level 4, and 5, etc....
Tim,
I tried your solution, but it only shows the next level childnodes and not all of them...
Anette
Hi Anette,
expandChildren="1"
and that
maxMenuDepth="999"
T
Hi Tim,
I tried again and now it almost works! :o)
Anette
Hi Anette,
I think I'm closer to understanding your requirements now.
Are you looking for behaviour like this: http://demo.thecogworks.co.uk/
I'm doing it on level 1 rather than 2 but the principle is the same.
If it is, then it can be done with the navigation package but you'll need to create some extra templates.
For this I created one master template and 3 sub templates
The 3 sub templates are homepage, contentpage1 and contentpage 2.
In each template I vary the params that are being passed to the macro in order to acheive the desired effect.
In the homepage I used this:
Then in Content 1 I used this:
Then in Content 2 I used this:
But this might be enough to get you started!
T
Hi Tim,
Your demo shows what I want, but the templates could get a little crazy as I have 18+ level 1 nodes!
I really appreciate your help and I hope you'll get 5 mins... :o)
Anette
Hi.
Did u see my post at 10/16/2009 3:52:59 PM
I forgot to remove the hardcoded level 2 in my example.'
/Jacob
Hi Jacob,
Yes I did see your post and tried that but it still didn't do what I want it to... if you look at Tim's demo above that is how I want my menu to be.
Anette
Hi Guys,
So. example
<ul>
<li><a href="somepage"><img src="mnu_prdocuts.jpg"></a>
<ul>
<li><a href="somepage">subitem1 lvl2</a></li>
<li><a href="somepage">subitem2 lvl2</a></li>
<li><a href="somepage">subitem3 lvl2</a></li>
</ul>
</li>
<li><a href="somepage"><img src="mnu_services.jpg"></a>
<ul>
</ul>
</li>
<li><a href="somepage"><img src="mnu_news.jpg"></a>
<ul>
<ul>
<li><a href="somepage">subitem1 lvl3</a></li>
<li><a href="somepage">subitem2 lvl3</a></li>
<li><a href="somepage">subitem3 lvl3</a></li>
</ul>
</li>
</ul>
</li>
</ul>
Hi Annette,
here's the link
Good Luck!
Hi Annette (and others)
Here's my take on this in XSLT - I've been using something quite similar recently:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:ms="urn:schemas-microsoft-com:xslt" xmlns:umb="urn:umbraco.library" exclude-result-prefixes="ms umb"> <xsl:output method="xml" omit-xml-declaration="yes" /> <xsl:param name="currentPage" /> <xsl:param name="root" select="$currentPage/ancestor-or-self::root" /> <!-- Specify level to start output at --> <xsl:variable name="level" select="'2'" /> <xsl:template match="/"> <ul> <!-- Apply templates to all nodes at specified level --> <xsl:apply-templates select="$root/descendant::node[@level = $level]" /> </ul> </xsl:template> <!-- This is how you want a single node to render --> <xsl:template match="node"> <li> <a href="{umb:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> <!-- Continue down this branch? --> <xsl:if test="descendant-or-self::node = $currentPage and node[data[@alias = 'umbracoNaviHide'] = 0]"> <ul> <xsl:apply-templates select="node" /> </ul> </xsl:if> </li> </xsl:template> <!-- Handle nodes explicitly hidden from navigation --> <xsl:template match="node[data[@alias = 'umbracoNaviHide'] = 1]" /> </xsl:stylesheet>/Chriztian
