  • Ryan Green 63 posts 83 karma points
    Feb 03, 2014 @ 17:11
    Ryan Green
    What am I doing wrong (probably simple solution)
    In my XSLT I want to create two variables. One for the Media Folder Id for the current page:
        <xsl:variable name="mediaFolderId" select="number($currentPage/mediaFolderId)" />
    And one for the Media Folder ID for the parent page. (So if there isn't a media folder ID present, it will pull the id from the parent.
    <xsl:variable name="parentFolderId" select="number($currentPage/ancestor-or-self::mediaFolderId)" />
    For some reason, the parent one is not working.
    Feb 03, 2014 @ 17:31
    Dennis Aaen
    Hi Ryan,
    TIf you know the nodeTypeAlias (e.g. 'Textpage') of your document type, you should use that:
     <xsl:variable name="parentFolderId" select="number($currentPage/ancestor-or-self::Textpage/mediaFolderId)"/>
    Otherwise, use the more generic:
     <xsl:variable name="parentFolderId" select="number($currentPage/ancestor-or-self::*[@isDoc]/mediaFolderId)"/>
    /Dennis
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Feb 03, 2014 @ 17:33
    2
    Hi Ryan,
    Sounds like you want what's referred to as the recursive value of that property (i.e., taken from the first ancestor where it's specified)?
    You can do that in one select:
    <xsl:variable name="mediaFolder" select="$currentPage/ancestor-or-self::*[normalize-space(mediaFolderId)][1]/mediaFolderId" />
    /Chriztian
    Feb 03, 2014 @ 17:35
    Ryan Green
    @Chriztian
    When trying your code, I get this error:
    System.Xml.Xsl.XslLoadException: Prefix 'ancestor-or-self' is not defined.
    Feb 03, 2014 @ 17:36
    Ryan Green
    @Dennis, this is the error I get with your code.
    System.OverflowException: Value was either too large or too small for an Int32.
    Feb 03, 2014 @ 17:37
    Ryan Green
    Here is my XSLT.... Basically, what I am trying to do is Use the mediaFolderId if it is present for the current page. If not, I want it to use the one from a parent page.
        <xsl:template match="/">
            <!-- Displays all images from a folder in the Media Library -->
          <xsl:choose>
        <xsl:when test="number($mediaFolder)">
            <xsl:for-each select="umbraco.library:GetMedia($mediaFolderId, true())/Image">
                        <xsl:if test="umbracoFile !=''">
                        <img src="/{umbraco.library:UrlEncode(umbracoFile)}" class="bgM" />
                        </xsl:if>
                    </xsl:for-each>
        </xsl:when>
        <xsl:otherwise>
            <xsl:for-each select="umbraco.library:GetMedia($mediaFolder, true())/Image">
                        </xsl:if>
                    </xsl:for-each>
            </xsl:otherwise>
    </xsl:choose>
    Yeah, sorry 'bout that - writing this on my phone, so had to fix a couple times :)
    Should be good now.
    Feb 03, 2014 @ 18:49
    Ryan Green
    The code above is not working. I pasted your code in, but it still doesn't work. Do I have something set up wrong?
    Feb 03, 2014 @ 19:37
    Ryan Green
    Got it working, I didn't change part of the code below in the Choose. Once I updated that to just mediaFolder it started working. Thanks @Chriztian
    Feb 03, 2014 @ 19:38
    Ryan Green
    Just for completion. Here is the working code. Including a default media folder of "4096" if there is nothing selected in the Parent.
      <xsl:choose>
                    </xsl:if>
                </xsl:for-each>
    </xsl:when>
    <xsl:otherwise>
        <xsl:for-each select="umbraco.library:GetMedia(4096, true())/Image">
                    </xsl:if>
                </xsl:for-each>
        </xsl:otherwise>
