  • Lasse 10 posts 50 karma points
    Feb 18, 2014 @ 08:24
    Lasse
    Problem with submenu with a specific number
    Hello Everybody
    I´m having a problem with my treemenu. I wan´t to style my vertical menu with CSS3 and JS. But I can't give my submenus a specific number with . (see my menu strukture on the images below)
    Is there another way to do it ? - PLEASE HELP ME
  • Mads Jørgensen 74 posts 226 karma points
    Feb 18, 2014 @ 08:41
    Mads Jørgensen
    Is it because you set
    <xsl:attribute name="class">child</xsl:attribute>
    And that overrides your class namer on your li's?
    Otherwise I'm not sure where you are trying to put in a number?
    Feb 18, 2014 @ 08:42
    Mads Jørgensen
    Your basic structure is rather OK actually,
    Feb 18, 2014 @ 08:45
    Lasse
    Tak Mads
    I can't take credit for it. _When I have started at this company, they already had the website up and running. I am completely new to Umbraco.
    What is the right way to do it ?
    Lasse Link to the page : http://hsasystems.com/about-us.aspx
    Feb 18, 2014 @ 09:01
    Lasse
    I wood like to put a number on my submenus. So it's easier to style
    Like this :
    <ul>
    <li class="submenu1"><a href="#">Something</a></li>
    <li class="submenu2"><a href="#">Info</a></li>
    ect.
    </ul>
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Feb 18, 2014 @ 09:35
    Hi Lasse,
    It looks like you just need two small modifications (provided the rest works as expected):
    Set a default for the level parameter to make sure it starts at one if you don't explicitly set it:
    <xsl:param name="level" select="1" />
    And add the level to the class:
    <li class="submenu{$level}">
    /Chriztian
    Feb 18, 2014 @ 09:46
    Lasse
    Thanks Chriztian
    That helped, but now they all named <li class="submenu3"> Why???
    Feb 18, 2014 @ 09:55
    101
    Hi Lasse,
    Ah - okay - my bad; I misunderstood :)
    Use the position() function to grab the index for the current item in a for-each:
    <li class="submenu{position()}">
    /Chriztian
    Feb 18, 2014 @ 09:56
    Mads Jørgensen
    Hep,
    try this:
    <xsl:for-each select="[your select statement]">
        <li class="submenu{position() + 1}">
    [alt dit andet indhold]
        </li>
    </xsl:for-each>
    Mads Jørgensen
    Damn you Chriztian... Too fast :-)
    Feb 18, 2014 @ 10:00
    Lasse
    TUSIND TAK DRENGE.
    Thank you so much - You just saved my day
    :-D
