I have a case, where i need to use some multi node treepickers several times on the same page, so i would like to reuse my xslt with the alias of the different pickers as a macro parameter...
So in theory i want to do this:
<xsl:variable name="thepicker" select="/macro/pickeralias" /> <xsl:for-each select="$currentPage/$thepicker/MultiNodePicker/nodeId"> <xsl:variable name="node" select="umbraco.library:GetXmlNodeById(.)" /> <xsl:value-of select="$node/@nodeName" /></xsl:for-each>
But this doenst work, because you can't inject a variable into a "node-set"...So how to go about this?
Hi Claus,
You can use the name() function for that:
name()
<xsl:for-each select="$currentPage/*[name() = $thepicker]/MultiNodePicker/nodeId">
/Chriztian
Heh... ehhh... thats... ehhh.... F...... AWESOME!!!!!!!!
Could it be any simpler?!?
Another beer for Mr. Xslteinmeier
Using mntp with macro parameter
Hi Claus,
You can use the
name()function for that:/Chriztian
