  • Garrett Fisher 341 posts 496 karma points
    Mar 05, 2014 @ 19:19
    Garrett Fisher
    Comparing Strings While Ignoring Letter Case --- XSLT concat() / FilterNodes()
    Hi, I have an interesting problem in a macro wherein I am building a search filter for use with ucomponents.xml:FilterNodes().
    The filter variable I am bulding works great with the dropdowns but when I am searching properties for a text string, my routine will only return lettercase matches. I am familiar with using the Exslt.ExsltStrings:lowercase() method, but because of how I am building this string using the concat function, I can force the original string to a given case but can't figure out how to do it on the property values with which I am comparing it inside the concat(). Here is the code (look for the "case-insensitve" comments):
    <xsl:variable name="filter">
      <xsl:if test="normalize-space($contains)">
        <xsl:variable name="containsString">
          <xsl:text>"xsl:text>
          CASE-INSENSITIVE
          <xsl:value-of select="$contains"/>
        xsl:variable>
        CASE-INSENSITIVE
            concat('[contains(@nodeName, ', $containsString, ')
            or contains(resourceDescription, ', $containsString, ')
            or contains(mediaType, ', $containsString, ')
      xsl:if>
      <xsl:if test="normalize-space($type)">
        <xsl:variable name="mediaTypeString">
          <xsl:value-of select="umbraco.library:GetPreValueAsString($type)"/>
        xsl:variable>
        <xsl:value-of select="concat('[mediaType = ', $mediaTypeString, ']')" />
      xsl:if>
      <xsl:if test="normalize-space($usecase)">
        <xsl:value-of select="concat('[resourceUseCases//nodeId = ', $usecase, ']')" />
      xsl:if>
      <xsl:if test="normalize-space($industry)">
        <xsl:value-of select="concat('[resourceIndustries//nodeId = ', $industry, ']')" />
      xsl:if>
      <xsl:if test="normalize-space($product)">
        <xsl:value-of select="concat('[resourceProducts//nodeId = ', $product, ']')" />
      xsl:if>
      <xsl:if test="not(normalize-space(concat($contains, $type, $usecase, $industry, $product)))">
        <xsl:text>[true()]xsl:text>
      xsl:if>
    xsl:variable>
    <xsl:variable name="filteredResources">
      <xsl:choose>
        <xsl:when test="normalize-space(concat($contains, $type, $usecase, $industry, $product))">
          <root>
            <xsl:copy-of select="ucomponents.xml:FilterNodes($currentPage, concat('
              ancestor-or-self::Home[@isDoc]//Resources[1][@isDoc]/ResourceType
              [@isDoc][not(umbracoNaviHide=1)]//*
              [(name()="LeadProtectedFile" and normalize-space(resourceFile))
              or
              (name()="LeadProtectedVideo" and normalize-space(embedCode))]',
              $filter))"/>
          root>
        xsl:when>
        <xsl:otherwise>
          <root>
            <xsl:copy-of select="$currentPage/ancestor-or-self::Home[@isDoc]//Resources[1]/ResourceType
              or
              (name()="LeadProtectedVideo" and normalize-space(embedCode))]"/>
          root>
        xsl:otherwise>
      xsl:choose>
    xsl:variable>
    I have struggled mightily with this -- just don't know how I can call a function inside the concat with all of the single and double quotes already going on, it's confusing me!
    Thanks in advance,
    Garrett
