  • Hudhaifa Yoosuf 28 posts 97 karma points
    Mar 25, 2014 @ 09:24
    Hudhaifa Yoosuf
    How To Use A XSLT Macro inside a cshtml macro
    i want to insert the macro which is marked it red . but it shows an error because i use it inside a macro
    this is the error below
    please give me a solution
    thanks in adavace
  • sami 22 posts 104 karma points
    Mar 25, 2014 @ 09:29
    sami
    Hi Hudaifa,
     @Umbraco.RenderMacro("UmbracoProductsListItems")
    Mar 25, 2014 @ 09:35
    Dennis Aaen
    Hi Hudhaifa,
    I never tried this before but it looks like you can use the library method called umbraco.library.RenderMacroContent
    http://our.umbraco.org/forum/templating/templates-and-document-types/33095-RenderMacroContent?p=0#comment121627
    Hope this helps,
    /Dennis
    Mar 25, 2014 @ 09:37
    Hudhaifa Yoosuf
    then an error pops
     Error loading MacroEngine script (file: )
    Mar 25, 2014 @ 09:47
    Hi Hudaifa
    Any reason why you don't just make one Razr macro to fetch your data? The mix of Razor and XSLT just feels wrong to me.
    But what version of Umbraco are you using and are you using MVC or webforms? If your templates are based on masterpages then you're using webforms. If they're based on views then you're using MVC. You can also check the
    Anyway the reason I'm asking is because things work differently wether you use one or another and also the Umbraco version matters.
    Mar 25, 2014 @ 09:58
    Hudhaifa Yoosuf
    i am using webforms.. and am using umbraco 6 version
    how can  i use include my xslt codes to cshtml macro.. should i inclde it as inline for razor
    Apr 17, 2014 @ 13:44
    Hudhaifa Yoosuf
    yeah i used a seperate razor thnx man it worked
